911 sc ignition leads issue
Just bought my first Porsche, 911 sc 1979, I want to change the plugs but try as I might, and im pulling hard, cant get the ignition leads off the plugs, am I missing something, do they unscrew or something rather than just pull off like every other car. I know from photos that there is a 'shaft' that goes down to the plug, and it looks like the ignition lead plugs into that, what am I doing wrong or do I just need to pull harder
They just pull off but may be stuck due to age/heat. Try twisting as you pull. Gently, of course. Use a bit of bulb grease on the ends when you reinstall.
Do you have the spark plug tool to change the plugs? If you have the factory tool kit it is the best one for the job.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
They'r probably just very tight having not been off for a while, or corroded, either way, if your replacing them anyway, just pull...
OOps,just noticed, you only want to change the plugs, so' in that case try and loosen them with a twisting motion like the previous poster sugests, this may help to un-stick them first before attempting to pull them. A...
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla Last edited by ant7; 03-06-2015 at 07:14 AM.. |
Thanks Wayne and A
Will try on Sat, spoke to the previous owner, last time they were changed was 8 years ago, but its only done like 2000 km since, they seened to rotate freely, I just need to be brave and get em pulled off, without breaking anything Thanks |
Wiggle while pulling usually works.
