| rpc356 |
03-13-2015 06:15 AM |
details of two-post ramps....
I got the ramps from Dambach Ramps ( #Dambach Ramps of New Castle, PA specializing in Ramps, ATV Ramps, Trailer Ramps, Heavy Duty Ramps, Wheelchair Ramps, Bobcat Ramps) about 10 years ago. They're 10' long and 3" high. I don't see them on their website, but at the time they were a stock item. The length is fine, but I was probably conservative with the height. You might talk to the folks at Dambach.
The ramps are attached to the lift with one bolt at each pad. It takes about 10 minutes to unmount or mount the ramps to the lift.
The approach ramps are 4' utility ramps my dad gave me. I drilled holes through the approach ramps and the tail of the Dambach ramp, and just drop a couple of bolts into each one to pin them in place for loading and unloading. Four feet works fine for the 356, but I haven't driven the (lower) 911 up there, so YMMV.
The wooden blocks are there to keep the ramps/lift arms from bouncing around while driving up.
The drip pan sits on top of a couple of metal supports that slip into homemade brackets.
I haven't tried to get the 911 on the ramps, since it only goes on the lift for working on it, with the ramps off. The ramps were set up for the 356 width, so I'm not sure how well this would work out for the 911, since the ramp arrangement is fixed.
http://forums.pelicanparts.com/uploa...1426255403.jpg
http://forums.pelicanparts.com/uploa...1426254929.jpg
http://forums.pelicanparts.com/uploa...1426255613.jpg
http://forums.pelicanparts.com/uploa...1426255770.jpg
http://forums.pelicanparts.com/uploa...1426255980.jpg
