Can anyone help?My turbo boosts to .4 bar then makes a high pitched sound and boost drops to 0. ..no smoke....Engine runs fine other than this. checked hoses and o rings and checked cool side impeller still rotates?Any thoughts would be greatly appreciated..thanks jerry mccabe
Have you checked out the wastegate? Could be opening too soon.
Check out pop-up valve that recirculates air around compressor on decceleration. If it's open you'll get no boost and turbo might overspeed, resulting in catasthropic shaft-failure.
First of all, detach rubber hose going to compressor-part and try to spin the shaft with your fingers. If it spins and doesn't have lots of play, turbo is OK. Then check out all hoses for rupture/leak, the popup-valve. Good luck! |
My turbo rebuild experience is limited to a unit on my 1964 Corvair Spyder but it sounds like there may be too much clearance in the oil pressure bearing or insufficient oil. It sounds like a chatter where the shaft is oscillating inside the bearing and then stops rotation. But it will spin freely for you by hand. If my memory is correct, it turned about 18K at idle and went up to 80K at full boost. I would be curious to know what you find. A good machine shop can help you measure all the components.
George 83 911Sc Cab/Euro |
