what is minimal power wiring to get 3.2 running
Anyone have an idea what the minimum wires I need to power to get the engine running are?
I am thinking: DME Fuel Pump Coil Gauge power Starter anything else? |
Altitude sensor also needed...
Jim Wolf ------------------------------------------------------------------- "WHEN WE START RUNNING YOU BETTER CATCH UP" |
You have to also get the speed, reference, CHT, AFM, and O2 also running, but there is an engine harness that these plug into. I suggest buying the wiring diagram and a good workshop manual, such as the Bentley Publishing one for the Carrera.
I have both the Bentley and the Haynes. I was hoping that I hadn't missed anything. I think, so far, I haven't. So I think my list is still correct and complete. |
Ok, well I guess you can just try it and find out. If Chewbacca could get the Millenium Falcon to fly out of Hoth, then you should be able to get a 3.2 911 to run on Earth.
Ha! The reason I am trying to double check is that I got rid of the old stock fuse box and wiring scheme and came up with my own way of wiring and powering the car. Going to smoke check soon...just didn't want to miss something obvious.
