What kind of 911 do i have?
Hello
New user here from Norway, making first post
I recently bought a 1977 Porsche 911 2.7 CIS, Chassisno: 9117302401.
The car has been sitting in storage for 17 years, and is in decent condition. Originally imported from Germany. The car has Turbo-look on it. Ive tried to figure out if this is original mounted on the factory or if it was rebuilt later, but havent been able to come to a conclusion. Did the cars with factory turbo-look come with different brakes?
The car has 8x15 and 10x15 Fuchs wheels on it.
What are these called? I Understand the 78 onwards with 3.0 are called SC. Is mine a 911S?
What are the main chassis differences between mine and the SC? As im thinking of converting to 3.2 and G50.
Thanks for replies
Tommy
Old 03-10-2015, 01:46 PM
gearhead
You have one of the last 50 1977 911 normal ROW chassis made.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 03-10-2015, 03:00 PM
gearhead
Look around at that tail closely. It might be factory. If so, it is worth some money. Also look at the part numbers and date on your wheels. Also worth some money. The flares are NOT original to the car, but could be factory steel.
1974 914 Bumble Bee
2009 Outback XT
Old 03-10-2015, 03:02 PM
Project Addicted
Looks like it's a 911S to me.
The 3.2 will be an easy swap but the G50 swap is a MAJOR bit of work to change out the torque tube and the back seat area sheet metal. It can and has been done and I'm sure if you search you can find info. The 915 trans in there now can handle the 3.2 just fine.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 03-10-2015, 03:29 PM
Thanks alot for your help guys
So i have to change some of the rear Seat sheet metal as well?
Going 3.2 turbo, and dont like mating that up to a 915
Old 03-10-2015, 10:41 PM
WPOZZZ's Avatar
Personally, I would keep the turbo body. You can stuff wider tires under the flares, thus a bigger contact patch which is beneficial with more power.
Old 03-10-2015, 11:21 PM
X2 you may have some expensive parts, part numbers if you can find them would be useful. Also post an interior picture or two, are those sport seats?
Nice project enjoy!
Lucky owner of a couple of 911’s and a 924
Old 03-11-2015, 03:36 AM
Thanks for yours replies guys.
The wheels have porsche part numbers and are genuine fuchs 8x15 and 10x15.
I fully intend on keeping the turbo look
Old 03-11-2015, 05:27 AM
Fuchs never made a 10x15, so you might want to check those rear wheels again. They made a 9x15 and an 11x15. A 10x15 would have to be a custom wheel made from part of a stock Fuchs wheel welded to a rim from another wheel.
If they are 11x15, they are worth some serious money. They look more like 9x15 wheels to me, than 11x15.
JR
Old 03-11-2015, 06:23 AM
Sry.
By measuring the rear wheels i found out that these are in fact 11" wide.
The part no on them are 911.361.020.11 as seen on the pic.
Old 03-11-2015, 07:58 AM
911.361.020.11 is the part number for an early 7x15 wheel. That's an indication that yours have been made from part of an original Fuchs wheel and another rim that has been welded on. Look for a 7x15 stamping near the Porsche logo on the back side.
A 9x15 is 911.361.020.03. An 11x15 is 911.361.020.05
JR
Old 03-11-2015, 08:21 AM
Ok
Thanks alot for the information
Old 03-11-2015, 08:54 AM
Project Addicted
The G50 is larger at the front end so the sheet metal is a bit different. There is a shorter end that can be used but I have never used it. This may allow for the sheet metal to remain.
Jon
1966 912
1986 944
Old 03-11-2015, 08:55 AM
gearhead
The torsion tubes need to be modified to install a G50.
1974 914 Bumble Bee
2009 Outback XT
Old 03-11-2015, 09:38 AM
scarceller's Avatar
Send pictures of the rear brake disks and calipers so we can see the trailing arms as well.
Then also send pics of the front ones and the front struts.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 03-11-2015, 11:11 AM
Rear:
Front:
Any info greatly appreciated as im completely new to Porsche.
Will 3.3 turbo brakes bolt straight on here?
Old 03-11-2015, 12:45 PM
scarceller's Avatar
Does not appear to have turbo rear trailing arms. So my guess is the wide body work was added at some point and not factory.
But it does have bilstien struts (green ones) at the front and that's nice.
Sal
1964 356SC (SOLD)
Old 03-11-2015, 01:00 PM
Cars and Cappuccino
tdw28210's Avatar
Will defer to those more knowledgeable, but real turbo brakes are mounted on the back side of the rear rotors. Those look like they are on the front side. Not sure if it matters or not when doing a swap.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 03-11-2015, 01:03 PM
scarceller's Avatar
Correct, my factory wide body has them on the back. This car seems to be setup as a stock narrow body car from the late 70s like the SCs.
Sal
1964 356SC (SOLD)
Old 03-11-2015, 01:09 PM
a G50 can be shortened to fit in a non-G50 body, hence no welding/cutting on torsion tubes. Not cheap however. There is somebody relatively close to where I live (Munich) doing that tranny work
Old 03-11-2015, 01:14 PM
