DCOP's Avatar
Early Dash Pad Fitment Issues
I am in the process of refreshing the interior of my 1970 911. I purchased a new (reproduction) dash pad from a fellow pelican. It appears to be new and I believe it is the same one aase sells. It looks great however upon installation the bolts and nuts that hold the speaker grille in are about a 1/2 inch long and hit the metal dash frame where the original speaker indentation is. This prevents the dash pad from lying flat as it should. It almost seems like I need to cut these studs off and glue the speaker grill in place. Grinding the studs/nuts would perhaps make too much heat and create additional issues. Not the fit I was expecting. Any advice would be appreciated.
70-911T/ RS Tribute 2.7
Old 03-12-2015, 06:33 PM
You might try a cut off wheel on a Dremel to shorten the studs. You can control the pressure and not create too much heat. You might have to dress threads on the ends of the studs.
Marv Evans
'69 911E
Old 03-12-2015, 09:44 PM
sleepy911's Avatar
Think I would just massage the metal dash a little to give room for the studs or drill holes. No risk to damaging the dash pad.
1969 911T build project (the slut) , 1959 356A (silver fox)
Old 03-12-2015, 10:32 PM
DCOP's Avatar
Both options considered and may have to use one or the other. Just a little apprehensive about cutting and drilling. Of course once it's installed who's going to know! I appreciate your words of advice.
Old 03-13-2015, 04:02 AM
