Suspension bolt - Grade
While I was crawling around under my car diagnosing my bad fuel pump I noticed a missing bolt. It goes through the auxiliary support on the front suspension and the bracket on the wishbone that holds the rear bushing. Bolt is part #90008202003.
Anyone know what grade this is? I found it locally in 8.8, but thought it might be 10.9. I surprised I didn't notice it handling funky or anything, should I have?
1971 Light Ivory 911T - Gretchen - sold Looking for Engine # 6114097 2010 Cayman |
Racer
I would get it in a 12.9 if I didn't buy it from Porsche....
Scott |
Recreational Mechanic
If we're talking about the same bolt the OEM bolt is 8.8 M12 x1.5. Front suspension cross member to body. Not sure if its different on a 71.
I just ordered one bc I found mine was stripped when doing some suspension work. Ordered an OEM Porsche bolt and was surprised it was only 8.8
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing Last edited by Nickshu; 01-07-2013 at 01:33 PM.. |
Thanks Nick, I had an order coming from PP, so I called to see if the bolt could be added. It's a special order part, but the sales rep told me he had just done his suspension and all the bolts with a few exceptions were 8.8
Tom
Best, Nick.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
AutoBahned
critical fasteners should always be checked against the PET for your particular model year
Tom
I found this thread while searching for some answers.
I was ordering some new fasteners while working on the rear suspension, and noticed that the M12x1.5x35 fasteners that clamp the spring plate to the trailing arm are grade 10.9, but the same size bolts for the rear calipers are grade 8.8. I then opened up PET to see if the grade is listed anywhere. The description for both bolts is simply M12x1.5x35 - however they have different part numbers. I guess this means that if you want to ensure you have the correct fastener grade for a given application, it is safest to order them by part number - but it seems a bit unsafe for PET to not list the grade in the description. So I have some extra grade 10.9 M12x1.5x35 bolts, but as I mentioned, the original caliper bolts were grade 8.8. Any harm in moving up a grade on these fasteners instead of purchasing new 8.8s?
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 Last edited by frankc; 03-11-2015 at 10:14 PM.. Reason: Fixed typo M12x15.x35 --> M12x1.5x35 |
Wouldn't that give an inadequate amount of preload on the 10.9 fasteners? More likely to loosen over time?
JR |
I bought the porsche bolts too as mine were stripped, and I am not convinced the thread pitch was correct. They screw in, but go in 5 threads or so and I have to shim about 1mm with a washer. I mention this because I bought the drop link kit for the rear a-arms, and it came with the bolts. For the life of me I couldn't get them to screw into the a-arms. Went in 2-3 threads and jammed. I got a pitch guage and the pitch was wrong!!! The pitch didn't match what the WSM said it was supposed to be, nor the original bolt pitch... Plan to check the pitch on the bolts in the spring... |
Max Sluiter
No, the modulus of the material doesn't change with the grade, and as long as the plating is the same the friction properties should also be the same, meaning the same torque-preload relationship.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
It ain't the modulus I'm thinking about...
JR |
Max Sluiter
Preload is dependent on modulus and stretch. (Modulus also affects the distribution of the stress between the engaged threads- lower modulus means more load sharing). Stretch is dependent on thread pitch and tightening angle. Angle is dependent on torque. Torque is dependent on the preload, thread pitch, and friction. Friction also keeps it from backing out. Use the same plating on the bolt and washer and everything should be fine.
Thanks for the responses. I was placing a fastener order this morning anyway, and just went ahead and added the 8.8 caliper bolts to the order since I didn't know how this would play out here at the time. Good info for the future, though.
While we are on this topic, I was trying to find information on when a hardened washer is required vs. a standard washer, but I was not able to find too much. Are standard washers only for grade 8.8, and hardened washers must be used for 10.9? What about 12.9 grade? Thanks.
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 |
Where else does the preload come from?
15 lbsft of torque on a Grade 12.9 fastener will be identical preload to that on an 8.8 fastener providing the friction is the same, so plating and finish are important. As Max says the Young's Modulus is what creates the preload and the pitch angles and other features of the screw thread stop if from loosening. As all threads are identical regardless of grade the only change is the load at which the bolt will permanently deform. It is , however, unwise to consider bolts in isolation they are used to clamp components together and this needs to be taken into account. Overtightening bolts as a strategy may be OK in terms of the bolt but may damage the components being bolted together. In the same way if you increase the strength of the fastener and tighten to the new maximum preload it is possible you could damage the component's being clamped together, hence the reason for my comment. |
The bolts of the spring plate changed about 1984 to 10.9 with increased torque The ones for the tranny beam where always 8.8 Higher grade does not any harm, only the price does
Roland 930 Turbo '81 Too many modifications to list |
The nut & bolt are designed as a set. Upgrading to a stronger bolt and applying more torque puts the nut at risk for stripping out. More torque is not always better as Chris_seven as alluded to. My suggestion is to replace with the exact same thing that the Porsche engineer designed for in the first place.
