Have decided flowmaster...which one for stock 3.2??
Hi all,
Car will have stock heat exchangers, premuffler, and something like the dual out Flowmaster. Which Flowmaster do I need for my 3.2? According to my searching/asking questions this seems to be best bang for buck. Thanks James |
Check out the 93-2004 Camaro/Firebird Flowmaster. 2.5 in, dual 2.5 out.
I have a similar setup(Flo-Pro) on my SC and I love it. Not too loud but screams at WFOT. About half the price of a Flowmaster at 80.00. I had one outlet capped off to keep my valence stock with one outlet. Check out any local speed shop in your area. I don't believe our fine host, Pelican Parts, carries them.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Here is my setup. The angle iron is to let the muffler "hang" on the factory hanger. I used two HD band clamps to secure it to the engine mount just like the factory setup. If you need more pics, let me know.
I'd love to see more photos....What did you have to do to the muffler to make it fit? If I wanted 2 out, would the muffler work with out modification (except for angle iron for mounting)?
Thanks Chris
'97 Boxster (Sold) '84 Targa - now a Cab (finally) Sold 1963 VW Transporter - Modified https://www.thesamba.com/vw/forum/viewtopic.php?t=668542&postdays=0&postorder=desc |
Administrator
Delta 80 Series, single 2.5-inch in, dual 2.5-inch outs. Both Jegs and Racer Parts Wholesale have it for about $100. It's part number 389-42583, a replacement muffler for a 1982-02 Camaro Z28/Firebird Trans Am.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Here are a couple more pics. The muffler fit my SC with no problems. I had a local muffler shop fab up the cap for the one outlet and the bracket. The pipe to the premuffler is 2.5. You can use the second outlet but you WILL have to modify your valence.
You can see the muffler hangs down below the valence just a bit. I am not into chrome so I just painted all the bits BBQ black. ![]() EDIT: Thanks for the part# Jack. I took my setup from yours, BTW.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne Last edited by Oh Haha; 08-10-2005 at 08:21 PM.. |
Thanks for the info...My rear valance/bumper is fiberglass so adding a second port wont be bad at all.....I am just looking for a better sound & more free flowing exhaust with out going broke.....
Thanks again Chris
Anyone ever dyno a similar set up vs stock, or vs stock with second tip added?
...sick with gearheadia |
In case you want to go Magnaflow ( A bit quiter but still a good scream at WOT)
![]() It now has Mandrel bent tubing and no actual tip, just a black painted end on the pipe it self.
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
Uber cool information! Anyone got a diagram (to show muffler shop) of the delta 80 installation for a 3.2? Or is it the same as Jack Olsen's 3.6 installation?
Sushinav, dyno info is available. Follow the link that Steve Wong gave me in the following response. You will find 3.2 test info in the 968 link he provided. For what its worth...he has shown me excellent customer service. That's worth alot in my books; Hi James, No bother at all, and thanks for your interest. If heat is not a concern, the best bang for the buck would be a set of 1 5/8 headers, (1.5" i.d) such as the Bursch you mentioned or a set of European George headers mated with a good flowing dual out sport muffler, such as a Monty, or you could make your own. The freer the muffler, the greater the hp output with the headers. If you need heat, then the GHLs are the larger diameter headers, second would come the SSIs, with it's smaller diameter pipes. If you just want inexpensive while cost effective, certainly a premuffler mated with a sport type muffler such as the Flowmaster or similar will give similar gains. The difference over the other setups, is that the headers usually gain you about 5 more hp throughout the mid to top end. With any type of setup, I have chips to match whichever setup you choose. You cannot make an exhaust on the 911 too free. It's just if you make the header diameter too large, you loose exhaust velocity at lower rpm, which create more backpressure than with a proper diameter primaries which have greater velocity. Here's a link you may want to look at, though the information is dated, it can give you an idea of what exhaust mods can do. http://www.968turbo.de/chipFAQ.html Although it doesn't say, test #2 is done with a european premuffler in place of the cat. If you have any other questions, or if I can be of further assistance, feel free to ask me. Best regards, Steve Wong -------------------------------------------- 911Chips - Porsche Performance Chips Bus: 323.819.0722 Fax: 323.953.2709 Email: steve@911chips.com http://www.911chips.com Thanks to all. James |
Administrator
Mark Wilson put my old 1-in, 2-out Flowmaster on his SC, and made this audio/video clip of it.
You can hear my Flowmaster in the 'see it go' clip in my signature.
I've got the single in dual out camaro flowmaster that fits a stock 3.2L exhaust. I ran it on my car for about a month. It sounded much better than stock and was lighter. I went with a different option that turned out to be a mistake. Should have kept the flowmaster on.
I'll sell you mine for $30 plus shipping. It'll need pipes since it's just the muffler at this point.
Installed Fabspeed bypass combo
Check out Gordens set up. Nice system that I will replicate very soon.
77 Porsche 911 3.0 Carrera 58 Porsche 356 55 Chevy Bel-Air 72 Volkswagen Bug, 06 Volkswagen T5 14 Yamaha R1, 14 GSXR750, 17 CRF1000 |
Southern Class & Sass
What is the part number for the Magnaflow? And where did y'all get the reducer to hook to the cat?
Dixie Bradenton, FL 2013 Camaro ZL1 Last edited by Dixie; 08-11-2005 at 03:08 AM.. |
What? No one knows the part number???
Dixie Bradenton, FL 2013 Camaro ZL1 |
Rob, I think BRJ had his MagnaFlow for sale here a while back. It may still be up for grabs.
another round please
masraum, sent you a pm.
Getting old is not for wimps. |
Man all I can say is ear plugs lots of them! I started the same way
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
I wish I could give you part numbers, my muffler guy "Just did it" It is a Camaro part though.
I like the sound on video of Ben's muffler. The 1in/1out wasn't available when I did mine. I did mine cheaply so the wife wouldn't get too upset.
The total was around 150.00 installed.
