Making my own 911 carburetors, The Ace
Hi
Thought I'd post a few pics of my ACE carburetor.
Hope You like it.
Old 04-24-2015, 01:03 AM
Wow!
Old 04-24-2015, 01:05 AM
Almost Banned Once
sc_rufctr's Avatar
Vary handsome. Do you have a pic of them installed on an engine?
- Peter
Old 04-24-2015, 01:07 AM
Thanks!
Not a very good pic...
They are currently on my 3.0L SC engine.
Old 04-24-2015, 01:21 AM
Slippery Slope Victim
NY65912's Avatar
Wow +1
Mike²
1985 M491
Old 04-24-2015, 04:09 AM
Why?
Old 04-24-2015, 04:48 AM
fireant911's Avatar
jon sigurdsen,
I worked in a brass sand casting foundry for many years. The sand mold for your carburetor is quite complex. The cored region looks like gluing was required (???). I do have a question about the metal rod used in the mold - does it remain in the mold during the poring process? We poured some parts using metal rods that were often quite difficult to remove. Are the carburetors produced from aluminum or some other material? I guess that the required machining far outweighs all of the other processes.
There was a video of the Ferrari manufacturing facility made several years ago ('Ultimate Factories' series). They showed the mold/core preparation is detail which was amazing! I imagine that your molds, too, require a lot of hand work prior to pouring. Your finished parts looks great!
Daryl G.
1981 911 SC - sold 06/29/12
Old 04-24-2015, 04:52 AM
I would rather be driving
jpnovak's Avatar
Oh, we are all going to need more information about this...
Bore size, jet compatibility. availability? Production?
Old 04-24-2015, 04:56 AM
Chain fence eating turbo
Very cool.
No matter how cool they are, how does it run? I'm sure well, but a video would speak volumes.
Very, very impressed.
How about whipping out some ITB's for EFI. Any plans?
If you can make a set of carbs, ITB's would be a cake walk!
Old 04-24-2015, 05:04 AM
Hi
Thanks for your interest!
The mold and cores are made from Petro-bond sand, The rod is actually a tube that helps alignment of the cores, and also alignment when machining the throttle shaft.
I use six ballbearings per throttle-shaft. The cast is alu. The finish is epoxy powder coat. The carbs use Weber IDA floats and jets. The bore on these are 42mm.
I'm thinking of machining them larger..
These are my first prototypes, I will make a few more later, and see if this is something I will continue to do.
Problem is: all the jets, floats and ball bearings gets very expensive..
The carbs runs great!
thanks
Jon
Old 04-24-2015, 05:33 AM
Das Schnell Ei's Avatar
very nice looking ! lots of work and a great job!
'77 911S Coupe 3.2 Turbo
'76 911S Coupe 3.0 964 cams...no sunroof
'75 911S Cabbie 3.2 SS Web cams & 46mm Webers
'73 914 1.7 Webers & Header ... sold
'74 VW 1303S 1600cc DP Web 110 & Solex
Old 04-24-2015, 06:20 AM
lpsalsaman's Avatar
Wow this is some awesome work! Impressive to say the least and if they are working flawlessly even more impressive!
U.S. Army Retired
85 Targa Guards Red
2018 BMW 530i M-Sport
Personal Quote: "Do whatever makes you feel good"
Old 04-24-2015, 06:25 AM
Uncle Enzo's Avatar
Amazing!
1976 911S
MidYear Fever is alive and well.
Old 04-24-2015, 06:49 AM
WOW - This take "DIY" to a whole new level.
Definitely let me know if you start doing ITB's...
Old 04-24-2015, 07:19 AM
CBRacerX's Avatar
Clap, clap, clap...
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 04-24-2015, 03:53 PM
Nice work,
Did you just buy the jets , venturis , butterflies etc from Weber or ??????
looking for information about old VW Coach built based sports cars, or photos and stories from the past ,
At one time many of these got confused as "Porsche prototypes" including the one restored at Hill and Vaughn in Santa Monica
Old 04-24-2015, 04:16 PM
I'll buy a pair
Old 04-24-2015, 04:55 PM
Almost Banned Once
sc_rufctr's Avatar
I'm actually thinking about making some ITBs for my SC. This has helped with some motivation.
(Anything available locally is well over 3k)
- Peter
Old 04-24-2015, 07:46 PM
Thanks!
Yes the jets and jet holders are standard Weber IDA / IDS. The throttles has to be made for different bores. So far I have bought the venturis, however these are quite easy to make.
sc_rufctr, please keep me updated if You start producing ITB's :-)
Jon
Old 04-25-2015, 12:10 AM
Great work! Is this a one off project or do you have plans to produce?
Old 04-25-2015, 05:14 AM
