Remove Oil Cooler without Engine Drop
I've found some threads which discuss removing the oil cooler (to replace seals) without dropping the engine, and some that say it's not possible.
My questions are: 1. Is is possible? 2. After removing the HE's, oil lines, engine tin, etc. is there a baffle on top of the oil cooler that needs to be removed? 3. Does anyone have experience with this? 4. Does anyone have a pic of that section of the engine? Thanks! Curt
68 912 77 911S 68 Dnepr MB750 80 Dnepr MT10 |
Oil Engine Cooler Removal.......
Some answers to your questions: 1). It is not impossible but would take a lot of skill and creativity. 2). Yes. There is a fiberglas top cover for the engine oil cooler. If you can reach and remove the inner bolt beside the engine thermostat, then removing the cooler is doable. 3). Someone may have tried this before. Not sure I would do it this way. 4). Yes. See pictures below. ![]() ![]() The degree of difficulty of achieving this task successfully without an engine drop is beyond my comprehension. Good luck. Tony |
I have removed my oil cooler before on my 2.4S MFI engine, as the oil cooler failed. It can be done while the engine is in the car, not so sure about a CIS engine. The cooler just pulls off straight away after you get the 3 nuts off. Several extensions needed on your socket wrench. YMMV
Bill '72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride. Last edited by zotman72; 03-08-2008 at 07:53 PM.. |
I was able to pull oil cooler on my 73 2.4T, to replace the three seals. It was a fairly straight forward operation. If I remember correctly, I removed the right rear wheel, the top duct and some sheetmetal.
Marty '73 911T 2.4 MFI |
Crotchety Old Bastard
Done on my 3.0L SC as well. NOT easy but can be done. The engine was dropped a few inches in my case.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
I have removed the oil cooler a couple of times on my 75 with CIS. I did not have to remove the heat exchangers or drop the engine. It helps to have a picture of what you are doing - like the one above - as you can't see what you are doing while working on it.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
There is a tech article on this subject by Stomski. Check out the tech articles section of this website.
I took the cooler off OK on my SC, partial engine drop and a bit of dexterity
needed, certainly a fiddle, I took the rear wheel off but didn't need to touch the Exhangers. |
Air Medal or two
Did it on a 2.7
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
I have a 1970E and was able to do it. The hard part was drilling out the rivits on the shroud to get the plastic top off the oil cooler, needed to get to the last 2 bolts. Other then that I was able to get to all the bolts from under the car.
1989 Cabriolet 1970 911E Sold |
I'm getting ready to help my friend with a neglected 911SC replace his oil cooler seals. I have to pack up my tools and drive 45mins to get there, so I need to be ready.
If it is necessary to drop the engine partially, do I need to disconnect the cv joints, or can I get away with just the shift linkage, harness, throttle, oil line, fuel, and cruise control? |
Air Medal or two
.. I think I did a partial drop (8 yrs ago) no need to unhook much..just 2 rear bolts as I remeber , Leave CV joints alone. seems there is one plastic cover that was hard to reach to get unbolted..anyway ( over the cooler ? )was not too hard or I would remember more about it.
Bring a floor jack so you do not over do your drop......LOL
Thanks afterburn. I am reading old threads, and they refer to 3 bolts and a plastic cover (see pics) over the cooler that may be a pita to lift so that you can move the cooler out of there.
How about on a 89 3.2L?
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Air Medal or two
I am no expert, did it on a 2,7 They are all about the same (i guess ) On mine I ended up doing a overhaul....had too many problems.thats an other story
I removed the oil cooler on an 88 Carrera to replace the seals. Time consuming but not difficult. I removed the air filter box to get access to the cover on top of the cooler. It helps to have thin arms and small hands.
John C 1988 911 Carrera coupe 2002 BMW 530 |
Always learning
Is it possible to do this without removing on a 3.2? Thanks.
On a 3.2 I know people have taken off the Fuel injection and intake to tackle the triangle of death in lieu of an engine drop.
I would assume it would be easy to get to the plastic top and engine cooler with the fuel and intake off?? Correct? Is this a viable option compared to a partial or full drop the engine? Or does the complete job require both a partial and intake removal? |
Air Medal or two
I am sure you can., you may have to remove exhaust and stuff in the way.
ok. I just checked my folder of handy tips.
On a 3.2 people have hit the triangle of death by removing only the air box and AFM. No Partial drop. My only question would be with the air box and AMF removed, would the Air cooler be accessible for removal? Ok, John C has answered the question.. It is possible with thin arms, small hands and patience. Last edited by Derek911; 03-15-2015 at 08:45 AM.. |
