Vacuum Moulding
While I've got my windshield out for my respray project I will be recovering my dash and side trim with Allsport 4 way stretch vinyl. I am going to be trying the vacuum forming method to do this. There is a commercial product made by Ziploc for cloth and bedding storage that works with a normal vacuum cleaner nozzle. The jumbo size is 35"x48"x16" so I think the dashboard will fit. The suction port has a rubber flapper valve to hold the vacuum after removing the hose.
![]() I suspect there may be a few out there who have experience with vacuum moulding. Would this off the shelf product work?
1986 Porsche 911 Coupe |
Try it on a scrap piece first.
I've done countless vacuum formed pieces of furniture components and I'd guess that a shop vac won't pull enough vacuum to give smooth results. My vacuum pump pulls 25 in/hg, which equates to roughly 150 pounds per square foot. A vacuum cleaner will only generate a fraction of that. -C
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
Won't work not enough vaccum.
Go to harbour freight they sell a vacuum pump that's strong enough. Also you need to heat the vinyl quite a bit
If a shop vac isn't strong enough I do have an air driven vacuum pump that's rated at 28 inches. I could probably adapt the valve on the Ziplock bag to accept the vacuum pump.
If the Ziplock isn't suitable what do people use for a bag?
ROW '78 911 Targa
There are adjustable zipper style vacuum bags. Try someplace like Smooth On or other mold making suppliers.
