Oddball carb set up
Just saw this on Craigslist. Not sure how it smogs?
1977 Porsche 911 Targa w a 3.0L and carbs
Old 03-23-2015, 02:55 PM
Carbs, like a holley 4bbl. Yikes. I wonder how they registered it in CA
206 637 4071
Old 03-23-2015, 03:21 PM
Wer bremst verliert
JohnJL's Avatar
Looks like a Holley or Edelbrock?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Rescuer of old cars
Arne2's Avatar
Pretty sure that it doesn't.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 03-23-2015, 03:24 PM
Bob Farmer makes them also. Despite the looks, they make good power and torque.
Old 03-23-2015, 03:36 PM
Speed Metal Army General
Despite the looks? I actually think they look pretty cool! If it does perform well, man that's as easy as it gets in comparison to dual carbs.. That said, the second example looks more engineered than the first..
Old 03-23-2015, 07:05 PM
I'll bet the fuel delivery is not as even as webers.
206 637 4071
Old 03-24-2015, 04:13 AM
djpateman's Avatar
Looks like there is enough volume in each runner for two cylinder fills, so throttle response may not be optimum. Usually, long runners also reduce fuel atomization which could cause poor fuel burn characteristics. Porsche ditched the central carb back in the mid fifties.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 03-24-2015, 04:43 AM
Reminds me of my old VW beetle days. Never had any throttle response or performance issues then. In fact, the beetle even felt peppier than some 3.2 Carreras that I have driven.
Old 03-24-2015, 05:58 AM
That set up would make for an easy EFI conversion...
MSD sells am EFI system that is like a carb, it has everything embedded, if the ECM can be made to work with a flat 6, i would be interesting.
Old 03-24-2015, 06:56 AM
Das Schnell Ei's Avatar
a double pumper holley is a lot of carb for a 3l .... setup right i bet it works really well
sure would make an easy way to put a n2o plate kit on too
'77 911S Coupe 3.2 Turbo
'76 911S Coupe 3.0 964 cams...no sunroof
'75 911S Cabbie 3.2 SS Web cams & 46mm Webers
'73 914 1.7 Webers & Header ... sold
'74 VW 1303S 1600cc DP Web 110 & Solex
Old 03-24-2015, 07:06 AM
