jedwards1123's Avatar
How to reinstall 6 pin rubber female sockets?
Is there a trick to reinstalling the 6 Pin rubber female sockets into their holes in the bulkheads and fenders properly?
I've been struggling to any of them to "pop" through so they properly seal. I've pushed an shoved and rotated but I just cannot work out how a single person can do this.
Any help?
Jeff in sunny Western Australia
1971 Porsche 911T (under restoration)
1967 Mercedes 250SL Pagoda
2007 Mercedes SL350
2014 Audi A1 Sports
Old 04-03-2015, 03:52 PM
83 911 Production Cab #10
JJ 911SC's Avatar
In situ Pics?
Who Will Live... Will See
Old 04-03-2015, 03:56 PM
Peter Zimmermann's Avatar
Lot's of Silicon Spray, get a portion of the lip through the hole, then twist with pressure.
Keep the Shiny Side UP!
Pete Z.
Stophos's Avatar
Or a little bit of common house hold dish washing detergent. I little drop will do it.
Old 04-03-2015, 04:00 PM
joefrantz's Avatar
I've found it pretty easy to lube the edges as recommended, then push them into place using a rounded blunt rod in the center opening (there is no contact in the center one).
It doesn't take much pressure and they pop right in. Emphasis on rounded blunt rod. I use a piece of scrap aluminum that just fits the opening.
Joe Frantz
73 911 T
Old 04-03-2015, 04:17 PM
JJ 911SC's Avatar
Originally Posted by Peter Zimmermann View Post
... then twist with pressure.
Normally from left to right but looking at your location it would be from right to left
Old 04-03-2015, 04:22 PM
