Thanks, Mike. I appreciate your responses.
Jeff |
My pleasure Jeff. I may have another new Hella replacement as described at the beginning of this thread. I was sending them to people for the cost of the switch and shipping ( about $15 total) until my original order of 5 ran out. It just requires one wire jumper to function properly in our cars (see thread details). If you are interested, then let me know and I will arrange to go to my hangar storage and search them out.
Mike |
Sure, I guess it can't hurt to have it in the event we're unable to figure out how to convert the wiring to a toggle switch. Please PM me your Paypal info and I'll transfer the money to you. Thanks.
I will see if I have any left first - it may be a week or two if I need to head to the hangar.
I used a DPDT - On / On switch. This switch has 6 poles with numbers 2 and 5 being common between the top and bottom halves. In the configuration above, the hazards work as expected. - Wire 30 (Constant power) energizes Wire 49 (Turn Signal Relay) - Wire 49a (Turn Signal Contact) is ganged together with the L and R Lights However, in the other switch position, the turn signal doesn't work properly - both L and R side lights come on when the stalk is flipped in either direction. This is due to having the L and R wires connected together at the switch. The only two wires needed for the Turn Signals to work properly are 15 (Key Start Power) and 49 (Turn Signal Relay). But when you connect the L and R wires together on the same switch terminal in order to operate the hazard setting, then you will always get both right and left side lights blinking when you activate the turn signal stalk. I tried multiple configurations on the switch but I was never able to get both features working at the same time. I am going to attempt to get an 8 pole On / On switch to see if I can get this to work.
Mat P 1988 911 Carrera |
That makes sense...thanks for trying and correcting it.
Yes, thanks. Still hoping I can add an aftermarket switch to my Rennline dash. I looked at my stock switch this afternoon and the difference between the switch diameter and the switch face is not that great, meaning if I decide to use the stock switch I have to be very careful not to drill too large of a hole. Fingers crossed that the 8 pole switch works.
Okay, so this is more like it based on OffCamber00's experimentation:
![]() 49a connects to L + R ONLY when the switch is engaged. They are isolated otherwise and the normal turn signal switching is active. Good catch. |
Jeff |
As a matter of fact, I finally got my 3PDT switch today. Little bugger was hard to find.
I'll mess with it this weekend and post an update.
Hey Mat, any luck yet? Come on, man, I'm counting on you since you obviously understand electrical wiring far better than I do! (shameless groveling intentional)
Did I mention I was born in Charlotte?
Gents - sorry for the delay. I was able to get the switch working in the configuration SpyderMike diagrammed out above.
I ended up buying 3 switches since they were a b!tch to find online - if anyone wants one, send me a PM. mat
I did this and it works perfectly
in fact I like the look of the toggle switch better than the flasher had and extra thru body plug, wired the toggle direct |
Full Send Society
Understanding the Emergency Flasher Switch
Never mind… answered my own question.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html Last edited by Showdown; 04-03-2023 at 07:29 PM.. |
Great write up Michael. I just replaced my flasher harness. New turn signal and i don’t remember a diode. My emergency flasher works, but my turn signals are not. What’s the role of the diode here? Thanks Rex |
It looks like 58 lights the switch when the headlight switch is activated. A diode prevents reverse current...so the switch does not light up in other conditions...only when the switch is activated...most likely. I see my Haynes manual describes this as a "resistor"...that would most likely just dim the light in the switch.
You say you have a new harness...is the EF switch an old one or a new one? From post 15, this is how the turn signal are power without the EFS engaged: Last edited by SpyderMike; 01-05-2024 at 08:39 AM.. |
New flasher switch New flasher harness New turn signal switch Old headlight switch |
Hmmm...On the above diagram focus on Turn Signal Contact (Switch). When the Emergency Flasher is not engaged, the current flows following the green path.
When the EF is engaged, the current can bypass the Turn Signal Switch via L and R terminals and the power comes from a different fuse 17 through terminal 30 on the EF. Check the wire at pin 30 on the EF Switch to see if there is voltage there. If there is voltage there then I would tend to shift focus downstream...is the voltage at 49a on the Turn Signal Switch? Quote:
I haven’t had a chance to chase why I'm not getting power, but i did jump 12V (switch side)to the green/black/white coming from the flasher to the turn signal switch. Flasher still not working with the switch, but i was able to get the left/right front/back lights to follow switch position to lite. I guess this is progress in trouble shooting.
Side note. I did learn my headlight switch has 1 set of male spades that are perpendicular to the switch housing and pics from the form are showing 2 sets of double male spades positioned perpendicular to the housing. My ignition switch was modified to remove the steering lock (cut/grind/lock delete) |
If you bypass the flasher relay, the lights will not flash. That is the purpose of that relay. Bypassing the relay and seeing lights work means that downstream path works.
See if you have 12VDC at 49 on the relay, if you can. If it IS there and yet noting is coming out when you turn signal, then you are down to 49a run between the relay and the EF Switch or the Turn Signal Relay itself, most likely. If 12VDC isn't at 49 at the relay, then you work upstream from there. |
