Understanding the Emergency Flasher Switch
On my 1985...
The switch is a standard Hella 001579-09 which is today available as a 001579-11. ![]() ![]() It has a mating connector attached to a short wiring loom. That loom is Porsche specific part number 911 612 014 31 I believe. Once the loom is separated from the switch you can read the contact designations (from the top clockwise): ![]() 30 - power in from always hot bus; a single red/black wire going through the connector on the front bulkehead to fusebox 1 fuse 2. 49a - two wires - one black/white/green going to the turn signal/headlight dim switch, and another black/white/green through the connector on the front bulkhead to position 49a on the turn signal relay. 49 - a single red/white going through the connector on the front bulkhead to position 49 on the turn signal relay. 58 - a single wire listed as brown (but mine is white) with diode P/N 911.612.249.00 connecting through a single pin connector to the headlight switch position 58a. 31 - a single brown wire with faston connector going to local ground. L - power out to the left side lights; a single black/white wire going the bulkhead connector. 15 - power in from the hot in start and run bus; a single green/red wire going through the connector on the front bulkhead to fusebox 1 fuse 8. R - power out to the right side lights; a single black/green wire going the bulkhead connector. The switch has a key molded into it to insure proper orientation during connection; you can see that near position L. The loom connector simply pushes onto the switch once the key is aligned. To remove the switch from the car, disconnect the loom from the switch and from behind the dash, squeeze the two plastic ears, and pull the switch through the front of the dash. |
Nice write up! How is the dash coming along?
1982 911 Targa, 3.0L ROW with Webers |
Hey Jeff,
I am done with the removal of systems and backdating the heat, relocating the battery and created new wiring scheme. I am finally hooking up wires now to the new fuse box. After that, I will get the car running and drive it to access the steering and brakes (since it has been a while). Then I will take it down again to deal with that and suspension. The interior makeover (dash included) will be down the list. Oh what a can of worms I opened... Mike |
Great info. Thanks!!
Mat P 1988 911 Carrera |
Whoa, do not buy a replacement switch using the part number I suggested until reading this post. I ordered the Hella P/N 001579-11 through Amazon Prime for $38 thinking that was a pretty good deal. Here is the Hella page for it:
Hella HD :: Hazard Flasher Switch I got the box today and it is Hella original, but it is a box of 5! Sure enough they list bulk qty = 5 for that part number. There is no part number for a single item. ![]() ![]() The differences: The original has the clearer plastic and the new is black. The original says "Made in Germany". The new says "Made in India". The front red push button has a different icon on it, but this part just screws off so that you can access the bulb from the front. You can place your old on on the new switch if you want. Both switches feel the same and mate up to the loom the same. ![]() ![]() I will be testing it in the next two weeks when I finish my electrical redo. Mike PS if anyone wants one, let me know. I will make you a smoking deal. |
Subscribed. Thanks for sharing your expertise Mike.
Henry |
My pleasure!
Just as an added bit of info...the new switches I bought DO NOT come with bulbs. I used the one from my old switch. It is labeled OSRAM 12V 2W. I am not sure of the size. |
Okay, finally wired it up and and promptly blew a fuse. Looking at the terminal designations on the new vs old it looks like Hella may have switched a power and ground. I see that what was terminal 31 (ground) is now terminal 30b (power?) and what was terminal 58 (to the lights) is now 31 (ground). Interesting.
There were two folks that bought new switches from me...please follow this as I try to solve this one. Here is the schematic from Hella for the new switch: ![]() Comparing old and new schematics it looks like socket wire 31 needs to be relocated to position 58 according to old switch designations (or 30b switched to 31 according to the new switch designations), then wire 49 need to be jumpered with 30b according to the new switch designations. Lastly, the wire with diode going to position 58 (old designation) is no longer needed. Cap and stow this one. This wire looks like it lit the switch when the headlight switch was pulled out. Mike Last edited by SpyderMike; 10-28-2015 at 03:40 PM.. |
Here is the Emergency Flasher circuit for the SC and Carrera years:
![]() Note the difference is the switching between busses 15 and 30 that power the relay through connection 49. In the "old" circuit the switch toggles between 30 - always hot bus and 15 - hot in start and run. Contact 58 powers the light on the switch from the light switch through a "resistor" it seems. On the "new" switch, the power from 15 is switched on or off to contact 49 but power from 30 to 49 is not available regardless of switch position. That is why I had to jumper 30b and 49. Then I moved the ground wire to the correct location labeled 31 on the "new" switch (position 58) of the "old" switch. It seems to work now. Last edited by SpyderMike; 10-28-2015 at 01:03 PM.. |
Putting both switches side by side in similar schematics:
Old: ![]() New: ![]() Last edited by SpyderMike; 10-28-2015 at 01:12 PM.. |
I did the two simple wiring mods above and the switch works.
Hi Mike,
I saw this thread a while back and committed its existence (although not its valuable details) to memory for future reference. The reason is I've deleted the center console but found that the turn signals won't work without the flasher switch connected. And I've replaced my dash with the Rennline version so would like to incorporate a simple two-pole (with ground) aftermarket toggle switch for the flasher because the plastic ears are broken on my stock flasher. I'm not as knowledgeable as you are about electrical wiring so excuse my ignorance, but could I just separate the wires bringing power to the factory switch (30, 15) from the wires leading to the relay, turn signal lights, and indicator lights (49, 49a, 58, L, R) and use a two pole grounded switch like this one? ![]() TIA for any advice you can offer. Jeff |
Subscribed. Would love to see this as well.
Here is my take for when the EFS is engaged:
![]() When the car is not running, the flashers will work because power is available from terminal 30 (always hot bus). When the Emergency Flasher Switch (EFS) is pushed in, power is then taken from terminal 30, and all of the outputs L, R, and 49a are ganged together and powered by the flasher. When you activate the EFS the red current flow is in play. Power comes in from terminal 30, powers the flasher relay, which in turn powers the left side lights of the car, the right side lights of the car and the two turn signal lights in the dash. The orange path to the left its the power to light the bulb in the EFS when the headlight switch is turned on so that you can find the switch at night. When the EFS switch is not engaged, then power from terminal 15 (when the car is in start or run key position), power goes to through the flasher relay, but the outputs are not ganged. Power goes to terminals 49a and into the light switch to only power the car lights and gauge lights on one side of the car. I think you could replace this switch with a simple setup, but not with a single pole single throw switch. To use that switch you would give up functionality (like allowing the turn signals to work). To maintain the functionality, you would need at least a double pole double throw switch I would think. The switch would energize the relay from terminals 15 and 30, and you would not have any EFS light to worry about. ![]() The outputs of the flasher relay 49a, L and R would need to be ganged together through one terminal of the switch. The power feed from the headlight switch and the ground from terminal 31 would need to capped and stowed. Does this make sense? |
By the way, this would be current flow without EFS engaged:
This would seem to replicate the switching in the EFS for all but the EFS light:
See below...original sketch removed to prevent mistakes... Last edited by SpyderMike; 11-14-2016 at 09:52 AM.. |
Excellent! Thanks Mike
I would definitely get a second opinion. Hang on, I see errors in my ways....the flasher is not getting energized this way.
This is more like it I think...still suggest someone more knowledgeable checking this before implementing.
I won't have time to test this out for a week or two but when I do, I'll report back here.
