chuffysplace's Avatar
3.6 conversion throttle linkage return
I am anew owner to a '86 930 with a 3.6 conversion, the previous owner or maybe the builder..not really sure, had a placed a return spring by the throttle linkage back by the transmission (drivers side rear area). The spring connects the linkage to a fabricated aluminum tab on the trans. It works... but not 100% of the time. It does not return correctly for that last little bit of pedal. On occasion it causes the revs to hang. Picking up on the accelerator temporary fixes this. I could try a heavier spring but I have to ask...is there a better way to make or buy a throttle return spring to do this? I've read that some people put return springs by the accelerator pedal under the floor but I am unclear how to access that area. I wasn't sure if it was a good way of doing this or if there are better ways to accomplish the same thing. I wasn't sure where to post this so I also posted this in the engine conversion section too. Thanks in advance.
1986 930, Instant G 3.6 Varioram Conversion, Cyntex chip, cams, solid lifters, custom exhaust, G50 trans, 22mm front and 29 mm rear, tarrett sway bars front and rear, strut tower brace, brembos, 18" turbo twist wheels
Old 03-25-2015, 05:04 AM
Mahler9th's Avatar
My race car uses a 993 induction system.
I came up with a way to add a spring to the pivot mechanism mounted on the engine. I wanted the extra tension to be as close to the TB as possible. This works well with the combination of parts I have, and perhaps it will give you some ideas for your car.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 03-25-2015, 08:53 AM
I see ok. Very Cool. Hey thanks for the info!
Old 03-25-2015, 03:19 PM
