Banned
brake lights come on with headlights
Hi all, I'm trying to track down a gremlin and looking for any feedback that can steer me in a certain direction.
All lights were working fine and then all of a sudden the brake lights stopped working, all the other lights in the tailights worked fine. Next thing I know, the brake lights are turning on when I turn on the headlights.
I've fiddled with the bulbs and even replaced the brake light bulbs in hopes there was just a bad contact. Nothing seems to work.
Also, with the brake lights on, they don't turn off or on when I depress the brake pedal.
Thoughts??
Old 03-26-2015, 08:54 AM
wwest's Avatar
Short between tail light circuit and stop light circuit, usually socket contacts.
Old 03-26-2015, 09:11 AM
Fleabit peanut monkey
Bob Kontak's Avatar
+1 on wwests comment
If you do have to remove the assembly to track down the short/cross-talk, there is a product from NAPA called Butyl rope. Its used to seal windows. If that grey caulk stuff falls apart, this is a perfect replacement for that seal on the back of the light box.
1981 911SC Targa
Old 03-26-2015, 09:43 AM
Banned
Thanks guys, I fiddled around with it some more and jiggled the bulb until it turned off while still in the correct position. After doing so I was able to get the passenger side brake light to work as it shoul. The driver side won't come on when the pedal is pressed. Both bulbs seem to be a bit loose in the socket so maybe just bending the contacts forward a bit will fix the problem.
Old 03-26-2015, 10:01 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Most likely you have a short in the assembly itself, bending the contacts may make it worse.
The sockets are on a Computer PCB board type material and is very fragile and brittle. This is the time to reinforce and crimp joints of the sockets with a mallet and a socket extension. I used JB weld and plastic milk carton as a backing reinforcement for the PCB.
PCB type board that fracture
joints that need to be re=pressed
Butyl rope would have been perfect, but I just used caulking to seal the back of assembly, 5 years later still working :-), Heck you might get lucky and the ground may have just fallen off.
'85 Carrera Targa
PCA/POC
Old 03-26-2015, 10:36 AM
