lin7310948's Avatar
lost key
i have succeeded in misplacing the only key i have for my 78 930. so what are the prospects of rekeying the switch portion of the ignition switch or just purchasing the tumbler portion with a proper key? any help or advice is appreciated.
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp
Old 03-27-2015, 10:19 AM
76 911S Targa
A locksmith can make you a new key. If you cannot drive the car, the locksmith can come to you. Have him make you two keys this time.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 03-27-2015, 10:26 AM
I've had that issue with other cars and have had good luck with Ellis Lock and Key here in Spartanburg. If you can pull the switch out, he can make you a key in a couple of hours. Last one I did was around $40. I'm sure there are other shops around Easley or Greenville that could do it too.
Though not original, a standard VW/Audi blank can be cut for our cars.
Old 03-27-2015, 04:11 PM
Bill Douglas's Avatar
Give the chassis number to the local Porsche agent and they will cut a correct key for you off the computer.
Old 03-27-2015, 04:16 PM
lin7310948's Avatar
thanks for the help...but the lost key was temporarily misplaced....i found it....just where i had placed it....i will get extras made!
Old 03-28-2015, 02:58 PM
You always find things in the last place you look, every single time!!
Tom
Old 03-28-2015, 04:34 PM
