Auxiliary spring bushings
I found one of the auxiliary spring bushings in the clutch release lever fell apart. Does anyone know if these have to be pressed out to be replaced, and how would one do that? Any assistance is appreciated.
Old 04-22-2015, 08:03 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Use a ID bolt and nut of the same size or use a vise. Do you mean the needle bearing?
a Pic would help greatly.
'85 Carrera Targa
PCA/POC
Old 04-22-2015, 08:18 PM
That's it, #10. Needle bearing. Bentley referred to it as the aux spring bushing. Thanks!
Old 04-22-2015, 09:17 PM
DRACO A5OG's Avatar
Oh okay, as I recall, this was 5 + years ago, I slipped them on the shaft then tapped it on???
Just make sure you put them in the same spot as the originals.
'85 Carrera Targa
PCA/POC
Old 04-22-2015, 10:19 PM
