-   -   What's the Best Way to Clean (http://forums.pelicanparts.com/porsche-911-technical-forum/858382-whats-best-way-clean.html)
grizzfan 03-30-2015 12:20 PM
As you can see, I have my alternator out and have to wait about another month before all the parts get back to me.
  • The engine looks a bit dirty and dusty from the air-cooling process.
  • Obviously I can't drive the car.
  • I have no access to water and car is in a storage unit.
http://forums.pelicanparts.com/uploa...1427743137.jpg
So, what is the best way to clean this puppy? I'm not opposed to some sort of spray cleaning liquid. I can roll her out of the storage unit too, I think!
Thanks,
Tom
Jerome74911S 03-30-2015 01:28 PM
To me that looks more like corrosion than dirt buildup. Is it really dirt?
Here's what mine looked like when I opened it up, same as you. There is more dirt sticking to oil seepage in my engine than you appear to have. I didn't have running water available either when I took this picture, but after wiping off as much crud as I could I used a degreasing agent (an orange based cleaner) with a rag, then wiped it off with water from a bucket that I brought to my shop.
Possibly you want a more complete 'washing' of the engine than I did, but a storage unit makes it tough. Can you place a large pan under the engine to catch falling dirt as you clean? Nothing makes the dirt magically vanish.
http://forums.pelicanparts.com/uploa...1427747131.jpg
Dpmulvan 03-30-2015 02:32 PM
losing battle
Trackrash 03-30-2015 03:16 PM
What's the oil cooler look like? The cylinders and heads don't look bad at all.
gtc 03-30-2015 03:37 PM
+1
Just leave it
Jdub 03-30-2015 04:01 PM
I would certainly have a look at the alternator ground (mesh wire to block) and clean that up, maybe consider replacing it if it is the original and hard to bend - you really want that ground in top shape and yours looks corroded to me. For now, grab some alum. polish and polish up or paint the fan - it can clean up pretty nice (for a week, anyways!).
I'd also remark that neither picture shows a center support strut across the middle cylinders (2; 5) for your air directional shrouds. Should there be one there?
Jerome74911S 03-30-2015 05:11 PM
Good question. I'd like to know, because I'm ignorant about this.
JJ 911SC 03-30-2015 06:51 PM
There is on a 3.2
http://forums.pelicanparts.com/uploa...1427766665.jpg
Jerome74911S 03-30-2015 07:00 PM
Originally Posted by JJ 911SC (Post 8554514)
That's not the same engine. What year is that?
grizzfan 03-30-2015 07:04 PM
Jdub opines:
Well you all certainly got my attention on this one. But, I don't quite understand what you are talking about, sounds serious, please elucidate.
Thanks,
Tom
JJ 911SC 03-30-2015 07:13 PM
Originally Posted by jerome74911s (Post 8554536)
that's not the same engine. What year is that?
86 (3.2)
JJ 911SC 03-30-2015 07:21 PM
Originally Posted by grizzfan (Post 8554544)
Jdub opines:
Thanks,
Tom
Tom,
What engine do you have? See Red arrow below. Also your engine may not have the piece with the white arrow.
http://forums.pelicanparts.com/uploa...1427768473.jpg
JJ 911SC 03-30-2015 07:49 PM
Jdub opines:
Thanks,
Tom
I think that you are OK as there is no other hole on the separator to run a stringer across cylinder 2 (5) as per younger engine like the 3.2
http://forums.pelicanparts.com/uploa...1427770148.jpg
grizzfan 03-31-2015 09:24 AM
Tom,
My engine is a 1975 911S (some call it "Carrera")
Looks like I'm OK by your last post.
Tom
