Question What's the Best Way to Clean
As you can see, I have my alternator out and have to wait about another month before all the parts get back to me.
  • The engine looks a bit dirty and dusty from the air-cooling process.
  • Obviously I can't drive the car.
  • I have no access to water and car is in a storage unit.
So, what is the best way to clean this puppy? I'm not opposed to some sort of spray cleaning liquid. I can roll her out of the storage unit too, I think!
Thanks,
Tom
Old 03-30-2015, 12:20 PM
Taking it apart is easy
Jerome74911S's Avatar
To me that looks more like corrosion than dirt buildup. Is it really dirt?
Here's what mine looked like when I opened it up, same as you. There is more dirt sticking to oil seepage in my engine than you appear to have. I didn't have running water available either when I took this picture, but after wiping off as much crud as I could I used a degreasing agent (an orange based cleaner) with a rag, then wiped it off with water from a bucket that I brought to my shop.
Possibly you want a more complete 'washing' of the engine than I did, but a storage unit makes it tough. Can you place a large pan under the engine to catch falling dirt as you clean? Nothing makes the dirt magically vanish.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 03-30-2015, 01:28 PM
losing battle
Old 03-30-2015, 02:32 PM
Under the radar
Trackrash's Avatar
What's the oil cooler look like? The cylinders and heads don't look bad at all.
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-30-2015, 03:16 PM
gtc gtc is offline
abides.
gtc's Avatar
Just leave it
Graham
1984 Carrera Targa
Old 03-30-2015, 03:37 PM
Senior Member
Jdub's Avatar
I would certainly have a look at the alternator ground (mesh wire to block) and clean that up, maybe consider replacing it if it is the original and hard to bend - you really want that ground in top shape and yours looks corroded to me. For now, grab some alum. polish and polish up or paint the fan - it can clean up pretty nice (for a week, anyways!).
I'd also remark that neither picture shows a center support strut across the middle cylinders (2; 5) for your air directional shrouds. Should there be one there?
'78 Targa in Minerva Blue
Old 03-30-2015, 04:01 PM
Good question. I'd like to know, because I'm ignorant about this.
Jerome
Old 03-30-2015, 05:11 PM
83 911 Production Cab #10
JJ 911SC's Avatar
There is on a 3.2
Who Will Live... Will See
Old 03-30-2015, 06:51 PM
Originally Posted by JJ 911SC View Post
There should be...
That's not the same engine. What year is that?
Jerome
Old 03-30-2015, 07:00 PM
Jdub opines:
Well you all certainly got my attention on this one. But, I don't quite understand what you are talking about, sounds serious, please elucidate.
Thanks,
Tom
Old 03-30-2015, 07:04 PM
JJ 911SC's Avatar
Originally Posted by jerome74911s View Post
that's not the same engine. What year is that?
86 (3.2)
Old 03-30-2015, 07:13 PM
JJ 911SC's Avatar
Originally Posted by grizzfan View Post
Jdub opines:
Thanks,
Tom
Tom,
What engine do you have? See Red arrow below. Also your engine may not have the piece with the white arrow.
Old 03-30-2015, 07:21 PM
JJ 911SC's Avatar
Jdub opines:
Thanks,
Tom
I think that you are OK as there is no other hole on the separator to run a stringer across cylinder 2 (5) as per younger engine like the 3.2
Old 03-30-2015, 07:49 PM
Tom,
My engine is a 1975 911S (some call it "Carrera")
Looks like I'm OK by your last post.
Tom
Old 03-31-2015, 09:24 AM
