mm86911's Avatar
Question Steering Rack Spacers
Anyone have experience with these and was there a noticeable improvement in steering feel?
Already have the turbo tie rod upgrade and car is lowered. Am I correct to assume realignment would be needed after changing the geometry?
Mike - Atlanta
'86 911 3.2 Targa
Old 09-26-2001, 07:20 PM
interested in 911's
carrera's Avatar
Post
Lowered? By how much?
Is it lower than euro ride height?
What is your opinion on the turbo tie rod upgrade?
Old 09-26-2001, 07:26 PM
Early_S_Man's Avatar
Mike,
It isn't a matter of 'feel' ... bump steer is what would be reduced somewhat by using rack spacers, but only needed if you are lower than the 113 mm lower limit spec for your car. The 113 mm is computed by the difference between the measured height of the center of front wheel and center of the rear portion of the torsion bar ... p. 86 of the '84-'87 spec book.
Warren Hall
1973 911S Targa
1992 Dodge Dakota 5.2 4X4 parts hauler
Old 09-26-2001, 07:36 PM
MIK911's Avatar
Question
Hey, Early_S_Man,
How does the 113mm lowered spec compare to the more common measurement of lowering, eg 25.5" F, 25" R ?
My question is....if a car is lowered to Euro spec, is a bump steer kit needed? '86 Carrerra.
thanks
mike
Old 09-26-2001, 09:27 PM
No, I don't have a number to relate fender height to the factory ride-height specs, because fender height varies with different tire sizes!
The factory specs can be checked fairly easy with metal machinist's rules, and are independent of tire size variations FOR A REASON! The 108 mm +/- 5 mm spec was USA and European spec for all cars ... '65 thru '73!!!
No, any car adjusted within the factory 103 mm - 113 mm range doesn't need a rack spacer kit!
Warren Hall
1973 911S Targa
[This message has been edited by Early_S_Man (edited 09-26-2001).]
Old 09-26-2001, 10:06 PM
Colby's Avatar
Send a message via AIM to Colby Send a message via Yahoo to Colby
Post
I have my car lowered to euro spec and was experiencing bump steer, so I installed a bump steer kit (homemade using washers). The difference was drastic. The car literally kicked the steering to the side when going over bumps, it now glides over most bumps like it used to.
Here's the catch; I have "big" tires (225/45/17 and 245/40/17). They raised my height, so I lowered the body down again. So technically, if I had the stock Fuchs back on there, I would probably be a little lower than euro spec.
Colby
Old 09-26-2001, 10:09 PM
Senior Member
Zendalar's Avatar
Post
Oook, what are we talking about? My car does "follow the bumps" when driving on lousy road. What are the DIY things here that can prevent this happening?
Old 09-27-2001, 02:29 AM
rstoll's Avatar
Post
Zen, start simple, check the air in your front tires first.
Robert Stoll
83 SC
83 944
Old 09-27-2001, 03:49 AM
Author of "101 Projects"
Wayne 962's Avatar
Porsche Crest
Originally posted by Early_S_Man:
Mike,
Also found in '101 Projects' if you can't find a spec book...
-Wayne
Old 09-27-2001, 03:50 AM
mm86911's Avatar
Post
I'll need to measure height from torsion bar but know it is lower than euro spec (24.5" at fender lip) - 16x7 Fuchs with 225-50/16 P7000s. Car does "kick" back when taking a corner that's not perfectly smooth so I now understand the need.
1. Will raising the rack, thus changing angle of tie rods, affect toe setting??
2. Should I wait until I make other changes with align and balance?
Thanks for all the responses.
Mike - Atlanta
'86 911 3.2 Targa
[This message has been edited by mm86911 (edited 09-27-2001).]
Old 09-27-2001, 05:17 AM
