Bad news from the shop - R&P
Just got a call from the shop doing my transmission rebuild. They say my ring & pinion is in bad shape, and that at the very least I should find a good used one. I wouldn't know a bad R&P if you dropped it on my foot, so I'm going on trust here.
The irony is that I just bought the PHII bearing retainer and side plate, to be installed with this rebuild.
Any sources for a used R&P?
Old 10-31-2002, 10:42 AM
Nobody
bob tilton's Avatar
sorry about the bad news. call spencer or jim at EASY - 510 653 EASY. they're a salvage yard in emerryville, ca. ck their ad in excellence. solid shop and solid people.
bob
Old 10-31-2002, 10:49 AM
I am sure you tried Silver Star - what about Heavenly?
My dad's 80sc dropped a pin on his R&P. Ate the Ring up, it ran him $800 used...
Good luck.
Nick
'85 Carrera
Old 10-31-2002, 11:31 AM
what ratio. i may have one with shims. the bearing retainer plate being worn may have caused it.
206 637 4071
Old 10-31-2002, 12:58 PM
8:31
Old 10-31-2002, 05:02 PM
let me know if you can't find one locally. mine are complete with diff and all the shims. just swap them out and you're done. usually i get $450 for them, but perhaps i can cut you some slack.
206 637 4071
Old 10-31-2002, 05:14 PM
Bill Douglas's Avatar
That's bad luck.
But on a brighter note, how's the board coming on?
Old 10-31-2002, 05:23 PM
scottb's Avatar
John: I've read your posts for awhile on this board, and you're always helpful and insightful. Your offer of help here takes the cake, however. You're what this board is all about -- Porsche afficianados helping one another.
Way to go!
1984 Targa
Old 10-31-2002, 05:24 PM
JW - I'll call the shop in the AM and see what the progress on finding one locally has been.
The board is the only thing that's gone right this week. I took it out for "sea trials" today in a local olympic-sized pool (unheated). It floats great, and paddles pretty easily, but it is a tank @ 30lbs! 2 layers of 7oz on the deck and one on the bottom, plus a very generous hot coat will do that.
I'm already tempted to do a second board, but with a bottom of carbon fiber and a top of carbon kevlar; one layer of each, and with Blue foam instead of Super Green (10% lighter) Don't know how it would perform, but it would be breathtaking to behold.
I did a proper sand-down and polish up with this one; check out how the carbon fiber bit on the nose came out: (I still wasn't done when I took this shot)
Old 10-31-2002, 06:54 PM
billwagnon's Avatar
If there was surfing in Seattle, you'd be jammin', widebody!
Old 10-31-2002, 06:58 PM
Irrationally exuberant
ChrisBennet's Avatar
Originally posted by Wayne at Pelican Parts
Hey, can't you replace the ring and pinion without taking the transmission apart? Maybe put it off until later?
-Wayne
See what happens when you post at 4:30 in the morning? Just delete your post quick and nobody will know.
-Chris
Old 11-01-2002, 03:43 AM
