-   -   Tracked down both 8" and 9" Fuchs, what would you pick? (http://forums.pelicanparts.com/porsche-911-technical-forum/859706-tracked-down-both-8-9-fuchs-what-would-you-pick.html)
evan9eleven 04-07-2015 08:18 PM
Looking at a pair of 8 x 16 or 9 x 16 original Fuchs for the rear of my SC. These are in the 911 offsets to give me the look and fit I'm after. I know that the choices for 245 tires to fit the 9's are limited, and that the fit will be almost identical to the 8's on the outside edge. Potential cost differences aside should I focus on the 8's or is there a compelling reason to go with the wider wheels if the price is right?
DanielDudley 04-08-2015 01:54 AM
I prefer 7s & 8s. Only you know if you want more tire.
sc_rufctr 04-08-2015 02:17 AM
IMO, Go with the 8s.
michael lang 04-08-2015 03:46 AM
either way you go, you have a winning combination. you might as well flip a coin. at one time 9s were really the choice but now 8s/9s, are you really going to see the difference while you're in the car?
E900 04-08-2015 04:45 AM
I have 9's with 225 tires. Might be worth considering looks-wise. Looks a little tighter than 245 i think. Especially when lowered.
http://forums.pelicanparts.com/uploa...1428493128.jpg
http://forums.pelicanparts.com/uploa...1428493173.jpg
http://forums.pelicanparts.com/uploa...1428493198.jpg
http://forums.pelicanparts.com/uploa...1428493383.jpg
fred cook 04-08-2015 05:29 AM
Wheels...................
I have 7x16s and 8x16s on my SC. I am running 245-45x16 Falken rear tires on the 8x16s with no problems. In the long run, the 9x16s will likely be more valuable than the 8s, so why not "invest" in the future?
McLaren-TAG 04-08-2015 05:41 AM
Buy them both.
Karter18 04-08-2015 07:46 AM
I would also say buy them both. If you don't buy the 8"x16" can you refer me as I am looking for a set.
Jdub 04-08-2015 08:03 AM
Most folks cannot distinguish between the two, so either will give you a great look. I am running 7"/9" and must recommend the Bridgestone Potenza in a 245 configuration - freaking awesome footprint from behind esp. with a lowered car.
BTW, in alignment shop, after suspension rebuild, I was asked what configuration I wanted (Street, Race, etc.) and opted for pure Street. Even with this config., my rear wheels have a slight camber unlike the pics above.
Jdub 04-08-2015 08:05 AM
Oh, and be sure to roll your front fenders before you get the 7", esp with a 225 tire set.
Bleedsblue 04-08-2015 09:07 AM
If you have to pick between the two, 8s all day. Not enough selection in 245+ 16" tires to justify 9s, unless you can put race rubber. Then it's 9s all day.
JohnJL 04-08-2015 10:05 AM
OP, what do you have on the front?
evan9eleven 04-20-2015 01:02 PM
I'm running the stock 6x16 and 7x16 fuchs now, looking to move the 7's to the front with 205's, and 225's in the rear. 8's are sounding like the best choice.
Bill Verburg 04-20-2015 02:25 PM
depends on what you want
to maximize performance potential 8 & 9 will be wanted, 7 & 9 is one notch down and 7 & 8 another notch down. That said you want to optimize the rubber and other suspension components to get the most from the car. one potential choke point is the rear tires for 9, you would want 245/45 x16 there are only a few choices for the tire in a high perf street version, fortunately B/S RE11 and Toyo T1R are 2 of them.
nothing wrong w/ 7 & 8 as that was the factory sport suspension option for many years
DanielDudley 04-20-2015 06:40 PM
I seem to recall that if you want to run 8'' Fuchs in the front, you need 944 offset wheels.
Bill Verburg 04-21-2015 05:00 AM
correct, for 16" Fuchs only the 8x16ET23.3 Fuchs is possible in fron w/ stock front fenders and it's a tough fit, most that use 8" front use aftermarket wheels w/ more appropriate ET.
Alex973 04-21-2015 06:55 AM
oh you lucky devil, grab both 8,9 worth a lot more a week after your
purchase, good luck
Shaun @ Tru6 04-21-2015 07:36 AM
245s fit on 8s perfectly fine.
daleflesburg 04-21-2015 08:07 AM
8 and 9 inch wheels
I am using 205 55 16s on 8 inch rims and 225 50 16s on 9 inch rims. I personally like the look of a wheel rim that is as wide as the tire, and they handle just fine.
http://forums.pelicanparts.com/uploa...1429628865.jpg
redridge 04-21-2015 08:55 AM
thinking of doing 8" and 225s all around... add 5mm spacer in the rear.
Bill Verburg 04-21-2015 09:05 AM
They may fit but for maximum performance potential you want them on 9s
Bill Verburg 04-21-2015 09:09 AM
for 8's and maximum performance potential you do want 225/50
for 205/55x16 you would want 7.5, but since Fuchs never made a 7.5, 7 will do fine, 8 is outside the tire manufacturers spec range.
Racerbvd 04-21-2015 09:11 AM
Thank you Bill for pointing out the actual true about what tire sizes were designed for what rim width/ You are absolutely correct, and people tend to ignore the fact that the side walls play A big part in not only handling, but safety, and stretching buy putting on a rim to wide or bulging, by using a rim to narrow, while some think it looks cool, is not the proper or size and not designed for most of our styles of driving.
I have both 8s &9s, currently running 7&8X16s with 205/50/16s & 225/50/16s, this choice was based on a couple of things, one being tires available at the time (needed then in a day) the other, we get a lot of rainy weather in FL, and I switch back & forth with daily drivers and the 225s on 8 are less likely to hydroplane if I get caught in the rain.
http://forums.pelicanparts.com/uploa...1429632676.jpg
Das Schnell Ei 04-21-2015 09:59 AM
8" seems like extra wheel for no reason with a 225 on the front no?
