Need Drivers Door Mirror Mount Template Help! (70-71)
Hey Guys,
At some point in time a previous owner welded up the original holes on my 71 to install SC mirrors. I am bringing it back to original specs and cant see the holes where the original Durant mirror went.
If anyone with a 70-71 (maybe 69? 72-73? although I know these are flag mirrors) can take a pic and some basic measurements so I know where to drill and how big of a hole I need to drill would be awesome!
Thanks I appreciate the help!
Nick
Old 04-13-2015, 09:35 AM
Neilnaz's Avatar
Hi Nick, I don't know whether the attached picture helps you out:
Further to that when you open the door and look at the area behind where the mirror will be located you should see a pair of holes through the frame of the door which enable you to the nuts and washers that are needed to mount the mirror. You should be able to identify the location by using the picture and the holes in the steelwork.
I hope that helps.
Cheers, Neil
Old 04-13-2015, 04:18 PM
Thanks Neil, do you have a shot of the drivers side? Unfortunately, the holes that were there originally have been blown out to larger holes for modern SC mirrors. I don't even know what the original mounting holes are supposed to look like...or how many are there.
Old 04-13-2015, 04:21 PM
Neilnaz's Avatar
Hi Nick, no I don't have one available to me here at work. I can take a picture this evening. My car has a pair of Durant mirrors. (BTW that is my driver's side - I am in NZ so my car is RHD).
I will post a picture this evening of the LHS and maybe of inside the door to give you some guidance.
Cheers, Neil
Old 04-13-2015, 04:51 PM
mcaterino's Avatar
Here's my 1970 Driver's door. Wait until you get your mirror to drill, but I only had to use the front and rear of these holes.
The passenger door mirror (when optionally present) is intentionally not in the same place, since the viewing angle from the driver's seat is different. (Although in that picture posted by Neilnaz it looks like it is in the same place. I think the passenger side should be further up and further back. EDIT: I see he's got a RHD car, so it's correct for him.)
Mike
Michael Caterino
Clemson, SC
1970 tangerine (=Tiger Orange) 'T' targa
restoration: mk911.blogspot.com
Old 04-13-2015, 05:05 PM
78-911SC's Avatar
Neil hope this helps out. Pic is of a 70T.
PJ
78 911sc Targa
70 911T
Old 04-13-2015, 05:08 PM
78-911SC's Avatar
Mike is that a 70 door on a earlier car? Vented window.. Neil what mirror are you using?
PJ
78 911sc Targa
70 911T
Old 04-13-2015, 05:12 PM
mcaterino's Avatar
Mine's all 1970, but had undergone some 'improvements' when I got it. Now it's back to more or less original. It's a targa, but you know, until now I didn't appreciate that the opening wing window was a targa/coupe difference that year. Thanks for pointing it out!
Mike
Michael Caterino
Clemson, SC
Old 04-13-2015, 05:33 PM
Awesome! Thanks guys! Would you say the holes are roughly 1.5 inches from the top of the door?
Trying to get an idea here.
Old 04-13-2015, 06:18 PM
techweenie's Avatar
There are access holes on the inner panel that should provide an excellent guide to drilling the outer panel.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 04-13-2015, 06:25 PM
