Red Sox to the Marrow
fan/ altenator belt '81 sc
everyone,
I know this has been covered many times but I have a question regarding changing the fan belt. On the '81 it is behind the AC belt. I loosened the compressor and removed that belt. But I can not loosen the 24mm nut on the fan pulley. Any suggestions?
cb
Proud member of Red Sox Nation a.k.a. "The Fellowship of the Miserable"
'81SC Targa guards red
Old 02-21-2016, 05:32 PM
You have a handle with a pin on the end of a semi circle in the tool pouch. That holds the pulley half, now the 24mm will loosen it.
Bruce
Old 02-21-2016, 05:39 PM
i tried. obviously i am weak. i will apply more "elbow grease"!
Old 02-21-2016, 05:46 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Get a breaker bar on it with the proper pulley tool.
PO obviously over torqued it. 36ft lbs is all it needs
'85 Carrera Targa
PCA/POC
Old 02-21-2016, 10:32 PM
SCadaddle's Avatar
I seem to remember the spec on the fan pulley nut to be 29 Ft. lbs. but all bets are off when somebody before you used an impact tool.
Old 02-21-2016, 10:34 PM
Bill Douglas's Avatar
And... After you have successfully adjusted it with all the washers, you need to adjust it all again a week later when the new belt has worn in.
Old 02-21-2016, 11:11 PM
DRACO A5OG's Avatar
Doh! EDIT
Per Bentley 30ft lbs. My Bad, I am gettin old :-(
'85 Carrera Targa
PCA/POC
Old 02-21-2016, 11:39 PM
