Bad news from the shop - R&P
Just got a call from the shop doing my transmission rebuild. They say my ring & pinion is in bad shape, and that at the very least I should find a good used one. I wouldn't know a bad R&P if you dropped it on my foot, so I'm going on trust here.
The irony is that I just bought the PHII bearing retainer and side plate, to be installed with this rebuild. Any sources for a used R&P?
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Nobody
sorry about the bad news. call spencer or jim at EASY - 510 653 EASY. they're a salvage yard in emerryville, ca. ck their ad in excellence. solid shop and solid people.
bob |
I am sure you tried Silver Star - what about Heavenly?
My dad's 80sc dropped a pin on his R&P. Ate the Ring up, it ran him $800 used... Good luck.
Nick '85 Carrera |
what ratio. i may have one with shims. the bearing retainer plate being worn may have caused it.
let me know if you can't find one locally. mine are complete with diff and all the shims. just swap them out and you're done. usually i get $450 for them, but perhaps i can cut you some slack.
That's bad luck.
But on a brighter note, how's the board coming on? |
John: I've read your posts for awhile on this board, and you're always helpful and insightful. Your offer of help here takes the cake, however. You're what this board is all about -- Porsche afficianados helping one another.
Way to go!
1984 Targa |
JW - I'll call the shop in the AM and see what the progress on finding one locally has been.
The board is the only thing that's gone right this week. I took it out for "sea trials" today in a local olympic-sized pool (unheated). It floats great, and paddles pretty easily, but it is a tank @ 30lbs! 2 layers of 7oz on the deck and one on the bottom, plus a very generous hot coat will do that. I'm already tempted to do a second board, but with a bottom of carbon fiber and a top of carbon kevlar; one layer of each, and with Blue foam instead of Super Green (10% lighter) Don't know how it would perform, but it would be breathtaking to behold. I did a proper sand-down and polish up with this one; check out how the carbon fiber bit on the nose came out: (I still wasn't done when I took this shot)
If there was surfing in Seattle, you'd be jammin', widebody!
Author of "101 Projects"
Hey, can't you replace the ring and pinion without taking the transmission apart? Maybe put it off until later?
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Irrationally exuberant
See what happens when you post at 4:30 in the morning? Just delete your post quick and nobody will know. -Chris |
