puddy's Avatar
Front wheel hub help
I'm trying to identify this hub, it's on my 1975 carrera but I don't think its stock. It's currently using 965 front rotors which slip over the front of this hub. I want to get dust caps for them but want to make sure I get the right ones. I tried googling the part numbers but didn't find anything. Any help would be appreciated.
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 04-12-2015, 06:21 PM
group911@aol.co's Avatar
Date stamp says 85 but would need to see the other side to see if it's standard or turbo
Thanks,
Bob
group911@aol.com
Old 04-12-2015, 10:15 PM
puddy's Avatar
Ok I never realized that was a date stamp on there. That helps narrow it down a little. It's back on the car at the moment, I don't really want to take it all apart again. Can you tell me what to look for to determine if it's a turbo or not?
Cheers, Chris
1986 951
Old 04-13-2015, 02:46 AM
On a turbo hub, the spindle nut will be recessed into the hub and you have to go through hole in the side of the hub to get to the adjusting nut.
What number is your Carrera?
Thanks,
Bob
group911@aol.com
Old 04-13-2015, 04:40 AM
puddy's Avatar
OK thanks, my hub doesn't have the recessed slot for accessing the clamping spindle nut. So would that make it a regular 944 then?
My Carrera is #29 but not one of the desirable ones, it a US Carrera I believe. VIN 9115400029 also no longer numbers matching, quite far from stock.
Cheers, Chris
1986 951
Old 04-13-2015, 06:22 AM
Regular 911 from 74 to 89.
FS 1975 carrera no sunroof rear spoiler 2.7 euro motor
Thanks,
Bob
group911@aol.com
Old 04-13-2015, 06:32 AM
puddy's Avatar
Wow thats a beauty Carrera!!! I wish I could convert mine back to stock! Original motor is long gone 2 owners previous, now has steel turbo flares and most suspension replaced with aftermarket. Original mileage is unknown. Probably not worth anything more than a 911 hotrod to someone.
Cheers, Chris
1986 951
Old 04-13-2015, 07:55 AM
KTL KTL is offline
Schleprock
KTL's Avatar
My understanding is the 944 and 911 use the same dust caps. I believe the trick to using the 965, or other Porsche slip-on front rotors, in this way is the 944 hub is machined down on the outer diameter to make a hubcentric fit with the rotor hat inside diameter
Kevin L
'86 Carrera "Larry"
Old 04-13-2015, 08:21 AM
puddy's Avatar
I don't think my hubs have been machined but the 965 rotor slides over and fits perfectly. I"m going to borrow a dust cap from a friend tonight and see if it fits.
Cheers, Chris
1986 951
Old 04-13-2015, 08:34 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Might be the 914 cap i'm thinking of and not the 944. Look up the parts diagrams for 944 and 911 (porsche.com has them under Porsche Classic) and it looks like the 944 wheel hub cap is a different part number and uses a lock washer to retain it?
Kevin L
'86 Carrera "Larry"
Old 04-13-2015, 09:03 AM
puddy's Avatar
Holy smokes I never knew that Porsche resource existed!! Thanks for the info!
Cheers, Chris
1986 951
Old 04-13-2015, 09:21 AM
puddy's Avatar
Perfect, I found the part, its a 944 hub that has been machined or worn on the backside and the part number is partially missing, but now that I can see the official part number for that part, I know that the right part.
Thanks again!!
Cheers, Chris
1986 951
Old 04-13-2015, 09:38 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Glad you figured out what you're dealing with & glad to help. That's what the forum is for!
Kevin L
'86 Carrera "Larry"
Old 04-13-2015, 09:44 AM
