Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
inner or outer?
The two hoses that run to the MFI pump which one is the inner one and which one is the outer? I need the one that runs from the left side of the engine by the #2 spark plug up to the pump. which one is that?
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 11-01-2002, 07:18 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
I believe you are refering to the heat tube.
It starts from the heat exchanger as a high heat tube (spiral braced/heavy material)..then has a metal pipe (connector)...then changes to a light weight air tranfer tube (spiral braced/light weight)...to the left side of the thermostat on the MFI pump.
Hope this helps.
Bob
Bob Hutson
Old 11-01-2002, 08:03 AM
Tim Walsh's Avatar
ok, except I can't find one on PP. I've got a nice size hole in mine probably from a mouse. where would I look otherwise?'
Tim
1973 911T
2005 VW GTI
Old 11-01-2002, 10:16 AM
Early_S_Man's Avatar
Porsche Crest
Pelican carries them ... order one of each, inner one slips inside the outer one.
MFI Pump Pre-Heater Hoses
MFI Pump Pre-Heater hose-Inner, 911 (1969-73) A-110-295-00 $7.20
MFI Pump Pre-Heater hose-Outer, 911 (1969-73) A-110-296-00 $8.80
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-01-2002, 11:49 AM
Tim Walsh's Avatar
ya I saw that but which one's which. I need the one that runs from the left side of the engine to the MFI pump.
Tim
1973 911T
2005 VW GTI
Old 11-01-2002, 12:15 PM
Porsche Crest
I already explained to you that the two separate hoses go together to make one hot air hose assembly to be secured with a worm-gear clamp at each end ... that goes from the sheet metal elbow to the thermostat assembly!
The heavy, reinforced rubber hose is outside the engine compartment, and hasn't very likely been damaged by mice with 6-ply fabric reinforcement and a 1/4" wall thickness!!!
Warren Hall, Jr.
Old 11-01-2002, 12:40 PM
Tim Walsh's Avatar
AHH sorry I'm a little slow at times... Early S.. you're a god
the inner one's the one I need.
Tim
1973 911T
2005 VW GTI
Old 11-01-2002, 12:58 PM
Warren, easy big fella, Tim is new to MFI, and I remember being just as afraid of screwing something (big$$$) up with a bonehead move. Still am, for that matter. So, I just ask silly questions until answers percolate through bone.
By the way Tim, did you pull the engine/trans? Or decide to crank it first for diagnosis ? What's the latest?
Scott
Old 11-02-2002, 08:30 AM
