jmpowers's Avatar
Power windows don't work after steering wheel installation
I installed a new steering wheel last night and thought everything went great. Went for a drive tonight and the power windows won't work. Checked all the fuses and they check fine with the multimeter. Any ideas if I could have screwed something up??
Thank you
-John
1987 Targa -Diamond Blue Metallic
Old 04-14-2015, 05:28 PM
plumb4u2's Avatar
if you simply just replaced steering wheel I don't know how that could have screwed with your windows.
Do any of the 3 switches work?
Justin
84 Carrera Targa
98 F-150 4x4
Old 04-14-2015, 05:53 PM
jmpowers's Avatar
Everything else(lights, fans, wipers, radio) appear to be working.
-John
Old 04-14-2015, 06:01 PM
plumb4u2's Avatar
there is nothing in the steering column that would affect window operation
Justin
84 Carrera Targa
98 F-150 4x4
Old 04-14-2015, 06:05 PM
French Import
zippy_gg's Avatar
so you want BOTH steering and windows to work?
When you say you checked the fuses with a multimeter, did you check from one post of the fuse holder to the opposite post, or did you remove each fuse and check individually?
I am asking because an individual fuse may check OK but not the end-to-end (post to post).
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 04-14-2015, 06:09 PM
jmpowers's Avatar
I checked the copper elements, they all look fine (no burn marks) and tested OK with the meter.
-John
Old 04-14-2015, 06:14 PM
French Import
zippy_gg's Avatar
The copper elements on the fuses themselves or on the posts of the fuse holders, with the fuses installed? Big difference, hence my asking...
Gilles & Kathy
Old 04-14-2015, 06:17 PM
jmpowers's Avatar
25A fuse, location #1 closest to the front bulkhead, fuse pulled and checks ok.
-John
Old 04-14-2015, 06:40 PM
French Import
zippy_gg's Avatar
Check for continuity between posts with the fuse IN. Then check for voltage from the bottom post and ground.
You may have a good fuse but a bad connection because of oxidation on the wires.
Gilles & Kathy
Old 04-14-2015, 06:44 PM
jmpowers's Avatar
Gilles,
Thanks for your help with the diagnosis. And upon an autopsy it was discovered that I inadvertently bumped out the fuse entirely. I thought the end space was open. Installed fuse and life is great.
I appreciate your help.
Cheers
-John
Old 04-14-2015, 07:20 PM
French Import
zippy_gg's Avatar
Gilles,
Cheers
Glad all is working again.
Gilles & Kathy
Old 04-14-2015, 08:35 PM
