Installing koni fronts....
I am going to be replacing my koni front strut inserts this weekend on my '75 targa. Any tips on the process? So it's removal of the top gland nut- what do I need to remove on the bottom of the strut housing to pull the insert out? Is it just a pin at the bottom that holds the insert inside the housing?
Thanks guys |
Its pretty easy, but now is the time to replace the ball joint as well.
Instslled them this morning. Way easier than I had imagined.
Is it that easy on 3.2 pcar?
Quick question- it shows my 75 came with koni's originally so I bought replacement koni's. The struts I removed were black and had "made in Venezuela" on them. couldnt find a name stamped anywhere- were these boge inserts? Or an off brand?
+1 make absolutely sure of the part number. VIN is not always reliable if PO upgraded it like mine to an 86+ front struts with strut housing glan nut on the outside. So annoying, had to pay a re-stock fee and shipping to order the correct one.
It's a koni strut for sure. I'll dig the inserts out of the trash. I reused the gland nuts that were on the housing.
| All times are GMT -8. The time now is 12:26 PM. |
