Installing koni fronts....
I am going to be replacing my koni front strut inserts this weekend on my '75 targa. Any tips on the process? So it's removal of the top gland nut- what do I need to remove on the bottom of the strut housing to pull the insert out? Is it just a pin at the bottom that holds the insert inside the housing?
Thanks guys |
Its pretty easy, but now is the time to replace the ball joint as well.
72 911 Although it is done at the moment, it will never be finished. |
Under the radar
Instslled them this morning. Way easier than I had imagined.
Easywind
Is it that easy on 3.2 pcar?
**Cheekybird**1997 911 C2 - Arctic Silver 1977 911S Targa - Sienna Metallic 2004 911 Carrera 4S Cabriolet - Arctic Silver 1986 911 Carrera Targa - Guards Red (sold), 2000 911 Carrera Coupe - Ocean Blue (sold) |
Quick question- it shows my 75 came with koni's originally so I bought replacement koni's. The struts I removed were black and had "made in Venezuela" on them. couldnt find a name stamped anywhere- were these boge inserts? Or an off brand?
Member 911 Anonymous
Yes, pretty straight forward. Just make sure you loosen the brake line brackets as not to damage it when pulling the strut down and out of the fender. Oh yeah put a heavy rag at the top of the strut so you don't dent the fender. Ask me how I know?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Under the radar
You will have to show some pics. Lots of changes, different brands over the years.
+1 make absolutely sure of the part number. VIN is not always reliable if PO upgraded it like mine to an 86+ front struts with strut housing glan nut on the outside. So annoying, had to pay a re-stock fee and shipping to order the correct one.
It's a koni strut for sure. I'll dig the inserts out of the trash. I reused the gland nuts that were on the housing.
