Tachometer
81 911sc, tachometer jumps all the way up and comes back down on initial start up, stays pinned at the bottom after, any thoughts?
Old 04-14-2015, 09:38 PM
ROW '78 911 Targa
timmy2's Avatar
Check battery voltage when running at multiple rpm bands.
Often the tach acting like that is a sign the VR is failing.
Old 04-14-2015, 10:27 PM
Not to highjack this thread, but my Tach needle "blips" at engine start and shutoff, but pinned at zero all the time when running. Worked fine before a battery replacement. Perhaps also the VR?
1976 911S, sleeping for 13 years, back to life in 2013!
Old 04-15-2015, 04:33 AM
toddu's Avatar
MSD ignition?
Todd
'81 SC
Old 04-15-2015, 06:01 AM
Yes
Old 04-15-2015, 07:26 PM
toddu's Avatar
The older MSD ignitions sent a "redline" signal to the tach when first turning the key on. You can disable this with a kludgy "short circuit" step, or just ignore it. I'm assuming it works otherwise (the tach that is)?
The newer MSD boxes have this disabled by default and you do the kludgy step to enable it.
Todd
'81 SC
Old 04-15-2015, 07:29 PM
Warren did you check the VR as suggested by timmy2?
Today, no my Tach is dead. Wondering if it is voltage related
Old 04-16-2015, 03:53 AM
