wwest's Avatar
disappearing thread
Originally Posted by Ronnie's.930 View Post
Will, comments like that really devalue your condenser fan idea and push you into the "Reid" category (think, "crackpot"), as it is absolute Tom-foolery to suggest that simply adding small, electric fans to the rear deck condenser (an area that already sees a tremendous amount of air movement) in any measure equals adding/replacing tried and proven a/c upgrade components to the system.
Sorry, but as everyone knows the level of air flowing through the rear lid condenser during consistently low RPM operation on a hot day is quite clearly insufficient.
That's why the addition of the fender mounted condenser/fan is such a "bang up" job.
So ANY additional flow will be of "some" help. So how about a level equal to 2500 RPM..??
Which is what my CFM measurements indicate using my 2 Spal fans. Measurement is an average of 15 points evenly spread across the rear lid condenser inlet area.
I was worried about extra engine heating until I realized that the 930's intercooler and condenser contribute a lot more than the Spal fans that only operate when the engine cooling fan does not suffice.
Old 04-20-2015, 10:16 AM
