charles
ignition switch
Hi All
I replaced the electrical part of my ign switch (73 911) ~ 8mos ago (purchased from our host) .
Fixed my problem of not getting the key to turn fully cw to start engine.
Same problem has now resurfaced - can't get key to turn fully cw to engage starter.
Seems odd it would fail so quickly (car not driven that frequently).
Suggestions other than replace it (again)? Getting older and not a fan of being a contortionist to get at it again.
Charles
Old 04-19-2015, 03:10 PM
Fleabit peanut monkey
Bob Kontak's Avatar
There are two parts, correct? Mechanical and electrical?
I would lean towards the mechanical mechanism as the culprit. I have never done this on a 911 so shooting from the hip.
1981 911SC Targa
Old 04-19-2015, 03:14 PM
pete3799's Avatar
As Bob said....your problem is most likely in the mechanical side of the switch.
Remove key and spray some Blakecleen (or similar) in the key slot to flush it. Hold a rag under it to catch the mess. Then use some graphite, or lube of choice.
If your key is worn try a different one if you have one.
Pete
79 911SC RoW
Old 04-19-2015, 03:29 PM
+1 re Pete's suggestions. I used WD 40 after flush -- solved problem!
Old 04-19-2015, 03:55 PM
ignition switch
I would clean the battery cables and other various battery wires.
Old 04-19-2015, 04:01 PM
charles
Thanks for suggestions
I'll check battery connections, and flush switch w/ wd40
key is worn.
Charles
Old 04-19-2015, 05:44 PM
Sounds like the start lockout in the mechanical portion is acting up. If you cannot remedy your problem with the clean/lube action, take a look at this thread. It may inspire you, or discourage you.
Ignition switch - inside to fix START lockout
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-19-2015, 06:09 PM
charles
the ground post that screws into the battery was loose (not the ground wire clamp).
flushed key, added some graphite, and got charger on - car started 1st try.
OK to add locktite to keep battery post from working loose?
Good advise - thanks
Charles
Old 04-19-2015, 06:21 PM
+1...I wouldn't be surprised if this were the root cause to begin with. Had a similar issue once (with a Triumph).
Old 04-19-2015, 07:45 PM
Walt Fricke's Avatar
I wouldn't use Loctite on a battery or battery connection. Not designed for that kind of thing. Clean both parts - the lead post and the clamp - well (you could use emery cloth), put back on, and get it good and tight. Should stay put forever. There are conductive greases you could get to put on the post before you put the clamp part on, and they help stave off corrosion.
Old 04-19-2015, 08:41 PM
