Carreras tensioner upgrade
I just installed the left side tensioner and the new chain sprocket idler but there appears to be about an eighth of inch space on the idler shaft is there a spacer for in between the timing case and the sprocket idler????
Old 06-11-2016, 04:31 PM
Yes I believe there is.
76 911S
Land Rover 110 Defender
Old 06-11-2016, 05:04 PM
Could you post a photo?
Old 06-11-2016, 05:12 PM
Vintage Owner
Jack Stands's Avatar
Are your idler arms the later style or the early style with a spacer?
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 06-11-2016, 05:19 PM
If you have any play there...
1983 Porsche 911 SC Coupe - Camshafts & Timing Chains - Page 3
SHOPPING CART
Old 06-11-2016, 05:27 PM
If you have any play there, you need this spacer...
Hope that helps.
Cheers,
Louie
SHOPPING CART
Old 06-11-2016, 05:29 PM
sorry, forgot to add
Part Number: 930-105-513-00-M105
Bottom part of page 3.
SHOPPING CART
Old 06-11-2016, 05:37 PM
Yes they are the new chain sprocket idlers arms from pelican parts
Old 06-11-2016, 06:22 PM
Then no spacer needed.
206 637 4071
Old 06-11-2016, 08:02 PM
there is enough space for this screw driver to slide in
Old 06-12-2016, 10:09 AM
Old 06-12-2016, 10:24 AM
Old 06-12-2016, 10:28 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Per 84-86 katalog there is no spacer, but take note you do need a seal as I a sure you are aware.
Master JW knows.
'85 Carrera Targa
PCA/POC
Old 06-12-2016, 12:36 PM
