Havolas (guest)
Guest
Posts: n/a
I am having issues losing power for a second while driving my 1977 911S. It also died for the first time after idling for a few seconds from a cold start. I replaced the coil with an Accel Universal SuperStock Coil to no effect it still hesitates periodically while driving. Is this an okay coil to put on my car? I don't know what a CD box is, and I saw somewhere not to use a conventional coil. Confused. Thank you for your help!
This post was auto-generated based upon a question asked on our tech article page here:
Old 05-22-2015, 11:20 AM
The CD Box is a voltage amplifier used in the ignition system. I am not familiar with the ACCEL brand coil. The ignition coil you choose needs to be rated for 40,000 volts or more. http://www.pelicanparts.com/catalog/SuperCat/0787/POR_0787_ELIGNT_pg3.htm
Take a look here and purchase one of these if you think you have a bad coil. If not rated for 40,000 volts that coil may burn out your CD Box! Remember to check the basics first, spark plugs, distributor cap, points, fuel filter, fuel pump relay, etc.
Check out these articles for more information:
http://www.pelicanparts.com/techarticles/rice_ramblings/rice_ramblings-3.htm ] http://www.pelicanparts.com/techarticles/rice_ramblings/rice_ramblings-3.htm [/url]
http://www.pelicanparts.com/techarticles/911_static_timing/911_static_timing.htm
http://www.pelicanparts.com/techarticles/mult_MSD_install/mult_MSD_install.htm
I would also recommend picking up a copy of 101 Projects for your Porsche 911, in that book you will find the answers to many questions that you will have once you work on your 911.
http://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2014.cgi?SUPERCAT_FLAG=Y&make=POR&Context_make=&please_wait=N&LastVisited_input=&Previous_Section=&forumid=&threadid=&command=DWsearch&description=101+projects+for+your+Porsche+911&I1.x=0&I1.y=0&FILTER_997M=ON&FILTER_911E=ON&FILTER_911M=ON&FILTER_911L=ON
The book is only $22, and it WILL PAY FOR ITSELF during your first do it yourself project!!
- Casey
grateful user
don gilbert's Avatar
first thing you need to do is take the accel coil off, what you took off looked like a coil, but it a capacitor. Going to end up buying a very expensive cd (capacitive discharge) box. Next thing you need to do is buy a set of press. gauges to check 4 different system pressures, ei cold press...warm press. rest press. and system press. Cant go anywhere until all press. are verified correct. Your gonna need a book
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 05-22-2015, 12:42 PM
Originally Posted by Havolas (guest) View Post
... losing power for a second ...hesitates periodically while driving.
Classic ignition symptoms. Ignition cables? Plugs?
Old 05-23-2015, 07:23 PM
