Curious on the proper way to check the oil level.. Drained oil from both drains, put new seals on plugs chaanged the oil filter. Added 8 qts took the car out for a half hour drive. than tried to check level with car at idol, when I remove the oil cap the car sputter than dies......any suggestions
Mo money = mo parts
I see you are new to the forum. Welcome. Just a quick suggestion - many, many technical issues, particularly simple problems like yours, have already been addressed here and can be found with the search feature. It's best to search first, then post.
3.0 Engine Stalls when Oil Cap Removed
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
Also, you drained quite a bit more than 8...
Member 911 Anonymous
10.5 Quarts. (3.2s)
But to be safe, add only 9.5 then fill as need after she is nice, hot and engine on. If it dies when cap is open, indicates more than not that you have a vacuum leak. Oh yeah, Welcome Aboard, she a Beaut :-)
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Eva
Try the vacumm restrictor as mentioned in the pasted thread by gregwils.
If that's the issue, then start hunting vac leaks. But that can be a slippery slope and a PITA
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
or use the Cigar Method, just don't tel the wife
Project Addicted
In the meantime, you can pinch the breather hose to stop the HUGE vacuum leak and check the oil. I would use a set of vice grips and a rag to pinch it off.
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
Oil weight
Just would like to confirm you're using the correct weight oil. I know a guy who ran 5W20 until I asked him
He rebuilt his engine.You should be running 20W50.
Henri Owned for 21 years: '87 Carrera coupe Venetian blue |
Update, Porsche recommends 10w-60 for SC onwards. 20w-50 for earlier cars.
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
Make America Great Again!
10w-60w ? What? I love Alphas...had a GTV 2000.
