Tire size and type collection
Guys, I have owned my 73 911 for 36 years. It is a 2.7, and it used to be an autocross car(Mostly). I have stock 6" Fuchs wheels. I currently have 205/50 -15 yokohamas. I guess I am showing my age. I'm tired of the high revs, bottoming , and the jarring bumps. Give me some suggestions for a brand and tire size. I MIGHT do one autocross a year, so super sticky is not that important any more. and I don't do many miles at all- 500 to 1000 miles a year.
I'm thinking 60 series? , what brand is the hot setup? I don't care to change my wheel size. Thanks
Old 04-26-2015, 07:43 PM
76 911S Targa
I cannot say that I have a "hot" setup but I am running Toyo Eclipse 205/60/15. The PO had 215/60/15 on the rear and 205/60/15 on the front but with that combination I could not rotate the tires. I don't do any fast driving so maybe you want something different.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 04-27-2015, 07:41 AM
Hilbilly Deluxe
emcon5's Avatar
15" is going to limit your choices quite a bit. The Bridgestones I have been using happily for years are not made in 15".
A quick search on Tirerack show you about 30 choices in 205/50-15, compared to 174 for the 205/55-16 (stock front SC tires).
If it was me, for you stated needs, I would go to Tirerack and look for something with a treadwear number above about 300.
Modern tires have come so far, even the high treadwear ones stick pretty good, and are quite predictable. If you can notice the difference between a Bridgestone RE760 with a UTQG of 340 and a S-02 with a UTQG of 140 while driving on the street, you need to slow the hell down.
82 911SC Coupe
GTI Cup #43
Old 04-27-2015, 09:16 AM
