-   -   Dooh! need help with stripped speed nuts on front hood emblem (http://forums.pelicanparts.com/porsche-911-technical-forum/862602-dooh-need-help-stripped-speed-nuts-front-hood-emblem.html)
prairiedawgshoo 04-26-2015 07:01 PM
So there I was thinking, I finally better swap out my crest for a new one...got my 8mm driver out and unscrewed it like heck and nothing...the speed nuts just spin...now the crest is slightly loose and can't tighten it
please, any suggestions?!
thanks
Roger
azhodge 04-26-2015 07:13 PM
grab it with a needle nose and pull while turning. install new emblem with new nuts, buy an extra nut as I stripped one installing the new emblem, they are not robust.
prairiedawgshoo 04-26-2015 07:35 PM
Thanks...just tried it...no luck, pulled hard while turning and no luck...any other suggestions?
sc_rufctr 04-26-2015 07:44 PM
Awful dilemma. You may have to cut it to avoid damaging the badge or car.
I'd keep trying the pull and turn method.
EDIT::: Cut the speed nut, not the pin. (Dremel?)
timmy2 04-26-2015 07:46 PM
Slide a plastic body interior trim removal tool under the emblem and apply upward pressure as you turn the nut slowly.
prairiedawgshoo 04-26-2015 07:46 PM
At this point, I'm okay with losing the badge...I've got another one...what would I need to cut?
thanks
sc_rufctr 04-26-2015 08:09 PM
Try splitting the nut after you cut it on two opposing sides.
If it's original I'd try really hard to keep the badge intact.
prairiedawgshoo 04-26-2015 08:21 PM
Thanks Peter...I was able to use the interior trim tool to apply pressure to get the nut to back off...Thanks So much Timmy2 you rock...I was starting to vapor lock on this one!
I appreciate all the suggestions...you guys Rock!
good night
roger
DRACO A5OG 04-26-2015 08:22 PM
+1 wedge something soft under the badge to create some tension for the speed nut to grab onto.
When you are ready to install, learn your lesson and take it easy, the rubber washer will squeeze out if you torque too much, ask me how I know.
timmy2 04-27-2015 12:06 AM
Glad it worked for you.:)
My days in the body shop paying for college pay off occasionally.. ;)
