new 2.5 engine over heating, please help!! Ignition timing?
Hello everybody
i just finish my 2.5 engine rebuild. It has 9.7:1 86mm je pistons and 964 camshafts by John Dougherty, it has a cis injection.
The engine is running very hot, it gets to 230f just running at idle
It has no air or oil flow problems. New thermostats, and oil pressure relief valves and its not running lean
I suspect ignition timing has not being set properly and have no clue of what the values for this engine should be
I please ask for your help
Regards
Eduardo
Old 04-30-2015, 06:55 AM
Make sure your thermostat on the engine is a match for the dash gauge or the gauge you have if its not correct for the car.
If the gauge is pre 77 the sender has to be brass
If the gauge is post 76 you need the chrome sender.
Ignition timing should be 3 to 5 degrees before TDC
Bruce
Old 04-30-2015, 07:25 AM
Thanks Bruce
Does any one knows what should be the max advance for this engine at high rpm ?
Old 04-30-2015, 07:45 AM
wwest's Avatar
Had that happen years ago the rubbing block for the points was so worn that the points were barely opening....
Old 04-30-2015, 07:59 AM
Straight shooter
Lapkritis's Avatar
Engines tend to run hotter when new before they're broken in...
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 04-30-2015, 08:45 AM
The points gap is were it should be
Old 04-30-2015, 08:52 AM
The engine was completely rebuilt
Old 04-30-2015, 08:55 AM
I would rather be driving
jpnovak's Avatar
Do you have an external oil cooler?
Timing should be about 32-33 BTDC above 5K. That is a lot of compression for single plug so I would not go higher than this. You risk detonation.
I don't know what distributor you have so it is difficult to comment about idle advance spec without knowing if you have vacuum advance or not. I assume you took a 2.4 (84mm) out to 2.5 (86mm). Was this originally a 73.5 CIS motor?
Old 04-30-2015, 08:58 AM
This severely affects timing.. In a 'point type' ignition, always set the gap, (most accurately with a dwell meter) first, then set the timing.. Recheck the dwell to make sure it didn't change.. Always use distributor lube on the rubbing block of the points to slow down rubbing block wear..
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 04-30-2015, 08:59 AM
Jpnovak you are right about the engine. The cis system comes from a 2.7 35mm intake/exhaust ports. The distributor is vacum advance
Old 04-30-2015, 10:12 AM
jpnovak's Avatar
What is your timing spec now? at idle? At full advance?
Is the vacuum advance or retard?
Time to get out the timing light and see where you are. You might want to map the ignition curve as a function of rpm so that you have a baseline and know for sure that your mechanical advance mechanism is working properly.
Old 04-30-2015, 11:23 AM
Jamie is absolutely correct... If you can get the dizzy number, you can compare what you have to how the curve for your distributor is supposed to work.. Since your engine has been heavily modified, you may want to have one of the distributor guru's recurve it for you for the engine to perform at it's best.. BUT, as Jamie said, you got to find out where you are, first.. Many times things get 'over-analyzed'.. Back to basics, solves many a problem..
84 Mustang Turbo GT
Old 04-30-2015, 12:57 PM
Also need to know what octane fuel you use as that really affects how much timing you can safely run,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-30-2015, 02:29 PM
I'm using 93 octanes fuel.
Thanks all for your help!
Old 04-30-2015, 08:45 PM
Thanks Steve
Old 04-30-2015, 08:48 PM
This is my 1977 911 with a 1973.5 t engine. That is how i bought it
Thanks again for your help
Old 04-30-2015, 09:09 PM
T77911S's Avatar
the points gap is not critical. set the gap and set the timing. i have done LOTS of testing with different gaps and idle timing and engine temps. when wwest's block wore, that retarded the timing. yes the more the timng os set retarded the hotter the engine will run AT IDLE. once youi start driving the temp should come down if you have good cooling.
all the points do is provide a path to gound. thats why the gap is not critical. the 10yrs i owned my 77s i NEVER used a gauge to set my points, just eyeballed it. i tried setting them narrow and i tried setting them wide, i never could tell the difference. i would guess there is a point at at which they are so wide the CD unit would not have time to charge at hi RPM.
the only thing i dont know is how much wear of the block changes timing. but thats not your problem.
check on what bruce said about the sending unit.
check your loop cooler to see if it is getting hot if you have one.
bad engine Tstat? can it go in backwords? i had to change one on my 77 and that is the last time i have had one out.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-01-2015, 03:53 AM
Tags
ignition timing , over heating
