-   -   Is there a voltage guage that would fit the clock position (http://forums.pelicanparts.com/porsche-911-technical-forum/863279-there-voltage-guage-would-fit-clock-position.html)
jwakil 04-30-2015 09:05 PM
I'm tired of years of staring at the stupid useless nonfunctioning clock and would like to replace it with a voltage gauge (preferably). Is there any voltage gauge that would fit that spot and look like the other stock gauges. I have white face gauges with the black ring, which probably makes it a little harder but thought I would try. I understand the clock is 80mm in diameter. I'm not interested in fixing the clock.
93nav 05-01-2015 10:10 AM
Perhaps you already know, but there are several shops that repair gauges and have put voltmeters or whatever in the clock position. You may need a 'donor' gauge. Not sure of the cost or turnaround time.
North Hollywood Speedo???
Al Reed of Anaheim
Do a search on voltmeter.
Walt Fricke 05-01-2015 01:51 PM
If you just want a voltage gauge, you can buy ones which plug into the cigarette lighter. But they are not something you'd use for the clock hole.
A tuna fish can is just about the right size for this hole, so if you were into making your own stuff, that would be a good start. But the result, with a digital voltmeter or whatnot attached, would not look like a Porsche VDO gauge. Something like that could be made to hold a VDO voltage gauge, though, so it wouldn't look entirely out of place.
joe payne 05-01-2015 02:48 PM
Since my clock works and my tach needs a re-build, I'm thinking this: http://forums.pelicanparts.com/uploa...1430516871.jpg
jmpowers 05-01-2015 04:11 PM
Cool idea Joe
boss11 05-03-2015 06:02 PM
my clock doesn't work, so I set it to 9:11 :cool:
jwakil 05-04-2015 09:20 AM
If someone out there has made a VDO look-a-like voltage gauge that fits that position, I would be very interested.
Trackrash 05-04-2015 01:18 PM
I have been planning this for a while. I will take an old fuel/oil gauge and re-purpose it.
I believe you only need to use a resister and some calibration to make the gas gauge work as a volt meter. The oil level will be used as a oil pressure warning light.
Before
http://forums.pelicanparts.com/uploa...1430770651.jpg
After
http://forums.pelicanparts.com/uploa...1430770674.jpg
Hotrod911T 05-04-2015 02:09 PM
I can't recall exactly how I did this, probably 10 years ago. I think I dismantled the non-functioning clock and used the clock base and bezel from it and fit in the standard small VDO voltmeter with a handmade metal spacer ring. Went together easily and works great in our track car.
http://forums.pelicanparts.com/uploa...1430773714.jpg
tadink 05-04-2015 02:29 PM
gosh, I'm stunned - there are others whose clocks don't work???
I've had like a dozen Porsches thru the years and I don't recall EVER having a functioning clock!! :)
I LIKE the idea of having a voltmeter, that would be cool!
td
jwakil 05-05-2015 10:18 AM
Looks sweet, just what I'm looking for.
