jwakil's Avatar
Is there a voltage guage that would fit the clock position
I'm tired of years of staring at the stupid useless nonfunctioning clock and would like to replace it with a voltage gauge (preferably). Is there any voltage gauge that would fit that spot and look like the other stock gauges. I have white face gauges with the black ring, which probably makes it a little harder but thought I would try. I understand the clock is 80mm in diameter. I'm not interested in fixing the clock.
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 04-30-2015, 09:05 PM
Perhaps you already know, but there are several shops that repair gauges and have put voltmeters or whatever in the clock position. You may need a 'donor' gauge. Not sure of the cost or turnaround time.
North Hollywood Speedo???
Al Reed of Anaheim
Do a search on voltmeter.
Who, What, When, Where, Why and How.
Old 05-01-2015, 10:10 AM
Walt Fricke's Avatar
If you just want a voltage gauge, you can buy ones which plug into the cigarette lighter. But they are not something you'd use for the clock hole.
A tuna fish can is just about the right size for this hole, so if you were into making your own stuff, that would be a good start. But the result, with a digital voltmeter or whatnot attached, would not look like a Porsche VDO gauge. Something like that could be made to hold a VDO voltage gauge, though, so it wouldn't look entirely out of place.
Old 05-01-2015, 01:51 PM
joe payne's Avatar
Since my clock works and my tach needs a re-build, I'm thinking this:
jtp911
Old 05-01-2015, 02:48 PM
jmpowers's Avatar
Cool idea Joe
-John
1987 Targa -Diamond Blue Metallic
Old 05-01-2015, 04:11 PM
boss11's Avatar
my clock doesn't work, so I set it to 9:11
82 SC Targa Guards Red = Toy
04 E55 AMG Brilliant Silver = DD
04 Cayenne Turbo Platinum Grey on 22s = Previous DD
80 Wide body 12AT RX7 Black 350+ hp= Previous Toy
78 Alfa Romeo GTV Blue = My 1st Cool Car
Old 05-03-2015, 06:02 PM
jwakil's Avatar
If someone out there has made a VDO look-a-like voltage gauge that fits that position, I would be very interested.
Old 05-04-2015, 09:20 AM
Under the radar
Trackrash's Avatar
I have been planning this for a while. I will take an old fuel/oil gauge and re-purpose it.
I believe you only need to use a resister and some calibration to make the gas gauge work as a volt meter. The oil level will be used as a oil pressure warning light.
Before
After
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-04-2015, 01:18 PM
Hotrod911T's Avatar
I can't recall exactly how I did this, probably 10 years ago. I think I dismantled the non-functioning clock and used the clock base and bezel from it and fit in the standard small VDO voltmeter with a handmade metal spacer ring. Went together easily and works great in our track car.
Old 05-04-2015, 02:09 PM
gosh, I'm stunned - there are others whose clocks don't work???
I've had like a dozen Porsches thru the years and I don't recall EVER having a functioning clock!!
I LIKE the idea of having a voltmeter, that would be cool!
td
Old 05-04-2015, 02:29 PM
jwakil's Avatar
Looks sweet, just what I'm looking for.
Old 05-05-2015, 10:18 AM
