Coupe roof front drain tubes
Hi!
Replacing the headliner in my 1980 911SC and have tried to obtain the front WATER DRAIN TUBES, 911 564 821 01, #12 on 811-00. Pelican says they are NLA from Porsche. (Pelican has and I obtained the rear tubes.)
Does anyone have a source for these? If not, what is the size of the tubes?
Any help will be appreciated!
Brian
Old 05-01-2015, 12:01 PM
Uncertifiable!!!
Uwon's Avatar
Brian,
I'm in the same boat with my build. OD of drain pipes are 15 mm at rear and 7 mm at front. I sourced fuel hose and heater hose locally. I want to clamp both ends and am concerned that clamps available will be too bulky and show through the liner. Haven't solved this yet.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 05-02-2015, 04:19 AM
Johan. How about wire ties or heat shrink tube?
Bud
87' 911 coupe- guards red/ linen leather
Only thing better than owning one is driving it.
Old 05-02-2015, 05:16 AM
Johan,
Thanks for the info. Would an Oetiker clamp work for the drain tubes? (Haven't removed the headliner yet, so don't even know if the crimper can get to the clamp.)
Brian
Old 05-02-2015, 05:55 AM
