Brap
tmaull's Avatar
Dent Mystery - What the heck happened?
I found a mysterious dent on my 911 this morning and I cannot figure out what could have caused it. Weird rock throw? Vandalism? It's on the drivers side front fender, and the metal is bent out and down. What do y'all think?
1980 911SC Coupe 3.4
1995 Miata
2005 Tacoma
2009 Street Triple
Old 05-04-2015, 02:27 PM
Brap
tmaull's Avatar
1995 Miata
2005 Tacoma
2009 Street Triple
Old 05-04-2015, 02:29 PM
mikeferg75's Avatar
What's your tire size are the fuch's stock size? Looks like a rub at full lock?
1975 Carrera Coupe #391
1980 924 11k orig miles
1974 914 2.0 LE Creamsicle
1979 Dodge Lil Red Express
2015 Wrangler Unlimited, and a bunch of bicycles.
Old 05-04-2015, 02:32 PM
steely's Avatar
take a closeup and see if there are plier marks?
Tire looks ok? No rubbing?
what does the inside of the fender look like?
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 05-04-2015, 02:33 PM
Brap
tmaull's Avatar
Tire has a small abrasion in it, which you can see in the picture. 15in wheels, tires are 205/55R-16 Bridgestone Potenza RE-11A SL.
1995 Miata
2005 Tacoma
2009 Street Triple
Old 05-04-2015, 02:34 PM
I would rather be driving
jpnovak's Avatar
Common. Caused by pulling into a driveway or other embankment with wheel turned about 70% to full lock. The tire grabs the lip and pulls it down. You can probably find the matching spot on the tire where the fender rubbed or slightly cut the outer lugs on the corner of the tire.
roll it up and back into place with a wooden hammer handle or something similar. Not much you can do about the paint crack.
Old 05-04-2015, 02:35 PM
Brap
tmaull's Avatar
Gotcha, thanks guys. Bummer.
1995 Miata
2005 Tacoma
2009 Street Triple
Old 05-04-2015, 02:36 PM
Under the radar
Trackrash's Avatar
That started happening on my car when the ball joints started to get loose. You might want to jack it up and check to see if your struts, wheel bearings, a-arm bushings, and ball joints are tight.
You also might want to consider rolling the fender lips as well....
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-04-2015, 03:41 PM
I agree tire hit the fender.
Old 05-04-2015, 04:40 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1, you will need to put more neg camber and/or roll the lip. Alternative is to raise the fronts.
'85 Carrera Targa
PCA/POC
Old 05-04-2015, 05:39 PM
