nene's Avatar
"Kick" in the shifter..What gives?
Need some opinions here with my shifter still "kicking", even after replacing
tranny and engine mounts.
When driving and I let go of the gas pedal, I still feel the jerking of the shifter lever and it feels like something is loose and swaying back and forth.
I double checked the mounts to make sure they were still tight and all is good.
Opinions?
Serge
Old 05-06-2015, 03:45 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Kick?
Opinions?
Serge
Shift rod coupler?
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-06-2015, 03:50 PM
nene's Avatar
The coupler and all bushings were replaced recently.
Old 05-06-2015, 04:16 PM
Inspect the gearbox and engine mount and confirm they're intact (not broken). Visually inspect running engine while on a lift.
Sherwood
Old 05-06-2015, 04:29 PM
nene's Avatar
Good idea Sherwood! Gotta check it out!
Is this common?
Old 05-06-2015, 04:50 PM
Josh D's Avatar
The output shaft walking under load/no load can cause the shifter to move. This is usually due to a failing 4 point bearing or worn bearing retainer allowing movement.
Do you get any gear wine or change in pitch during load/unload?
Old 05-06-2015, 05:32 PM
midnight911's Avatar
clutch
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 05-06-2015, 09:08 PM
nene's Avatar
Josh,
No real noticable pitch.
Old 05-06-2015, 09:24 PM
