lespaul's Avatar
Tight Turns and Gas Smell
78 SC.
When I take tight turn and push it hard (interstate on-ramp), I get a whiff of raw gas. This even occurs with a half tank. Is this common and/or dangerous?
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
Patented in U.S. and Europe. Go to SNAPGAP.US or PM me.
https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146
Old 05-07-2015, 06:16 AM
You could have a small leak. Mine had similar situation and I was told its normal for an old car... until one day I turn on the car and fuel is pouring on my garage floor.
Should be no smell.
Old 05-07-2015, 06:34 AM
Check your gas cap gasket and rubber hose clamps on the tank filler neck.
Old 05-07-2015, 08:45 AM
nene's Avatar
Brad,
My situation was similar and it ended up being the gas cap, which I replaced and all fixed!.
Old 05-07-2015, 08:53 AM
wwest's Avatar
Replace the "crush" seals for the fuel filter.
82 SC's Avatar
I have the exact same problem with my 82. I think it could be some of the vent hoses around where you fill up. Happens with partial tank or more with a full tank.
1982 SC "Spooky"
1961 VW Single cab truck
1966 VW Deluxe Hard top
Old 05-07-2015, 09:00 AM
PeteT's Avatar
Had the same problem. Replaced the vent hoses that are connected to filler area. Kind of a pain to replace but only took about 30 minutes. After that no smell at all.
1983 SC
1958 TR3
2014 Cayenne GTS (wife' car)
2006 KTM 450EXC
Old 05-07-2015, 09:37 AM
Enthusiasm > Expertise
reddogmotrsprts's Avatar
I'd suggest making sure your replacement isn't a Cohline hose, or budget to replace it shortly if so. At least a couple of us have found Cohline hoses between one and three years old that were leaking. A search of the archives will turn up details...
Red Dog Motorsports
Old 05-07-2015, 09:26 PM
lespaul's Avatar
Thanks guys. I had purchased a new gas cap a while ago, but I think when I turn it to "tight" the seal is compromised. Yesterday, I filled up and turned it so it felt sealed buy not turned 100% of the way. 3 hours of hard driving and no smell so far.
Brad
Old 05-08-2015, 05:58 AM
moneymanager's Avatar
Just take the gasket out of the cap, put something... rubber, cardboard, plastic.. cut in the shape of a gasket in with the gasket on top of it. You just want to make it a little thicker. Simple.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 05-08-2015, 10:40 AM
