aralunan
Send a message via Yahoo to aradsinc
Hi Casey
Thanks for the advice...I have a stupid question ....how do you check the residual fuel pressure loss ?
tnks
Tony
This post was auto-generated based upon a question asked on our tech article page here:
Old 05-08-2015, 10:00 AM
You will need to connect a fuel pressure gauge between the fuel injection pump (on the engine) and the fuel filter, or if it is easier you could T in to the fuel line at the fuel filter. Basically anywhere between the pump which is under the car in front, and the pump which is located on the engine. You will run the car, and then turn it off. Observe the pressure. It should drop, then stay pretty constant for about 15 minutes. Then try to restart and see if you have your same issue, while having an assistant observe the gauge. What you will probably find is that the pressure drops off and when trying to restart the car it never builds back up. If you are REALLY crazy like I am... read this: http://www.flatsixaddiction.com/pelican/MFI_Check_Measure_Adjust.pdf ] http://www.flatsixaddiction.com/pelican/MFI_Check_Measure_Adjust.pdf [/url] You will find the specs you need in there, and enough information to help you figure this problem out. In my opinion the Mechanical Fuel Injection system is the COOLEST system ever, and after reading this you'll understand why!!
Here is our version: http://www.flatsixaddiction.com/pelican/MFI_Check_Measure_Adjust.pdf ] http://www.flatsixaddiction.com/pelican/MFI_Check_Measure_Adjust.pdf [/url]
Use the bottom link for the adjustment manual not sure why the first one doesn't work...
- Casey
aralunan
Hi Casey
Your the best !!! Tnks you said it like a true professional !
Tony
Old 05-08-2015, 04:18 PM
