Transmission to Engine M10 Fasteners Torque Spec?
I hate to ask such a simple question here, but I'm trying to find the torque spec for the four M10 fasteners (3 nuts, 1 bolt) that hold the 915 transmission to the engine. I looked in the factory workshop manual, the "Tech Spec" booklet, Bentley, 101 Projects, Haynes, and searched the web, but I can't find this number. The closest I found is 46-48Nm (34-35.4ft-lbs) for the separate starter M10 nut.
Does anyone know where I can find the torque value for these four fasteners? Thanks, Frank
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 |
Spiderman
Torque numbers
Wouldn't they just be the "typical" torque numbers found in Bentley for every engine and tranny fastener ?
M8 - 25 NM or 18 ft-lbs M10 - 42 NM or 30 ft-lbs. M12 - 80 NM or 58 ft-lbs. Just torque based on size normally. Can go less if not structural is how I view it. I rarely torque maintenance items but engine fasteners get more attention if I've got it out of the car as I'm taking time and being clean.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Straight shooter
Would recommend a little blue loctite on the threads here. Dry assembly can gall and come up short on fastener torque.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
I just find it odd that Bentley has left out such a fundamental torque setting because they are usually pretty good about listing the specs needed per section (although I have found them to be wrong on many occasions).
It's a trap...
Well Frank, what did you do? I saw the starter torque too but nowhere else but the generic torque chart.
Run like the wind, straining the limits of machine and man.... 2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys). |
I did end up finding the torque values for these fasteners in 911SC Bentley when I was looking for something else. I don't have access to the Bentley manual at the moment, but check the the section that covers engine removal and separating the engine and transmission - I think it may have been there.
It's a trap...
OK, thanks. I found a 33 ft-lbs in the starter install section. I used that, it was close enough to the generic 10mm torque that I felt that was good. Cheers, Mike.
Well, I have never measured the torque on these. Just use a 17mm wrench and tug hard. Wrenches have lengths which kind of set the torque you can apply, so overtorquing is unlikely. I've never had one loosen. This is not like head bolts or cam carrier or case through bolts or rod bolts.
Of course, torqueing to spec won't hurt anything. Just takes a bit more time. |
It's a trap...
Thanks, on the driver side bottom I had to use the calibrated arm method. Couldn't get a socket on it and no crowfoot. Cheers.
