sithot's Avatar
3 Spoke Sport Steering Wheel malady
Is there more than one "horn pad" made for these wheels? I have one of the wheels with the very thick 1/8" (not stamped/pressed) spoke assembly. Came with a pad but it sits down on the wheel on the posts so tightly that the horn is always engaged. As soon as it is placed on the steering shaft and pushed "home" and makes contact with "the contacts" on steering wheel assembly it lights off!
There is no movement once the pad is pushed onto the face of the wheel.
Makes me long for the '75 Carrera wheel I let go with a car years ago!
Thanks.
R Gruppe #111
Early S Registry #235
res ipsa loquitur
Old 05-11-2015, 05:54 AM
KNS KNS is offline
Are you missing the little springs that keep the pad off the hub?
Kurt
Old 05-11-2015, 09:45 AM
Discseven's Avatar
Thinking same as Kurt. Those springs can pop off easily.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 05-11-2015, 07:05 PM
sithot's Avatar
Thanks for the replies.
Slight alignment issue. Got it worked out and tested it tonight. Looked at 2 other identical wheels today (one was NOS). None took much movement of the pad before the contacts touched.
R Gruppe #111
res ipsa loquitur
Old 05-11-2015, 08:53 PM
